Re: How rare is Blue top on My '67 GTX conv.??
[Re: MuscleMopars]
#207586
01/29/09 01:01 PM
01/29/09 01:01 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
I'm pretty sure it's supposed to have a glass back window so the top might be an aftermarket one and the wrong color.
pretty sure 68 was the first year for glass rear window .
[Re: RoadRunnerJD]
#207591
01/29/09 10:21 PM
01/29/09 10:21 PM
Posts: 7,547 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Cool. Probably rare. The original color would be a lighter blue. The original rear window would be glass and be etched with a pentastar. The top color is listed on your broadcast sheet - top right corner under code 30. "2" is white. I don't know the code for Black or Blue. Even though the rear is plastic, it's still possible the top is original and only the window got replaced. If the top is original, check the vinyl "grain". I could only describe it as being a very very tight small diamond pattern. If the grain is "leather" it's very likely to be an aftermarket replacement. Keep us posted. Got your b.sheet? - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: SCATPK]
#207593
01/30/09 12:41 AM
01/30/09 12:41 AM
Posts: 2,209 NYC
MRVCODE
NYC
Would a black top be available with a white car and a blue interior? Or would blue or white be the only available top colors.
yes. My 69 GTX convetible is white,blue gut, black top.I also use to own a 67 Belvedere convertible, silver, blue & silver interior,blue top.
[Re: SCATPK]
#207595
01/30/09 09:07 AM
01/30/09 09:07 AM
Posts: 22,900 Gabba Gabba Hey! NYC
Diego (not Ted)
In addition, black (as well with white) goes with everything, so it's not unusual to see cars like this.
[Re: 69CoronetRT]
#207596
01/30/09 12:30 PM
01/30/09 12:30 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
In 1966 you had a choice of white, black, or a blue tops material, grain was called "Pinpoint". They all came standard with plastic rear windows, a glass rear window became available through parts but not installed on the production line.
In 1967 you still had your choice of white, black, or blue top material, grain was the same "Pinpoint". Regardless of what the factory litterature posted above may state, early build 67 cars still came with a plastic rear window, glass was still available through parts, however sometime during the production year it was changed to glass as standard. To date I'm not aware of a solid changeover date.
[Re: ScottSmith_Harms]
#207597
01/30/09 09:38 PM
01/30/09 09:38 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
My 67 R/T is a late 66 build, with a plastic backglass.. The new top will definetely be getting a glass backglass....
