Re: FINALLY got me a 360..
[Re: DARTH V8Я]
#2074894
05/17/16 01:09 AM
05/17/16 01:09 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Also I've seen a lot of things in my life, but never, NEVER had I ever had all the exhaust manifold bolts come out without a hitch! Guess VC leaks were a good thing in my engines case. To quote Spock.. "Fascinating".
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2074899
05/17/16 01:27 AM
05/17/16 01:27 AM
Posts: 4,457 Washington
madscientist
Washington
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) expect a package later on ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks. Pretty straight forward on SRL install. I question the head deal myself. But, and this is a big butt, to go 9's in a 3100 pound car takes about 595 HP and in the correct combo any Pcar head can do that.
[Re: DARTH V8Я]
#2074903
05/17/16 01:34 AM
05/17/16 01:34 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW. @ thumperdart you bet buddy :thumb: & duly noted ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) expect a package later on ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks. If you buy the right lifters there shouldn't be any grinding. I've seen Dan's stuff run, there is no bs there, it runs hard.
[Re: DARTH V8Я]
#2074904
05/17/16 01:39 AM
05/17/16 01:39 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am going to lurk in the background on this thread because last Monday I bought a 360 in pieces from a guy on Craigslist. It was a 1990 roller cam engine, the block was standard bore and had been hot tanked but not bored, the heads had been rebuilt and came with a Delta Cam regrind (new). The crank seems to be standard, but I also have a fresh .010/.010 stock stroke crank. It also had a truck pan and factory windage tray. He gave me a new mini-starter with it and some other scrap iron, intake & exhaust manifolds. So I think it was worth the $150.00 I paid for it. It will go in the DD when it is done.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: DARTH V8Я]
#2074915
05/17/16 02:21 AM
05/17/16 02:21 AM
DARTH V8Я
Its a TRAP!
Well that's good to know the Pcar heads can get up and boogie! What kind of compression are you guys getting away with on an iron headed with 92oct E10 swill?
[Re: DARTH V8Я]
#2074934
05/17/16 03:29 AM
05/17/16 03:29 AM
madscientist
Washington
11.08:1 on pump gas.
[Re: DARTH V8Я]
#2075022
05/17/16 11:27 AM
05/17/16 11:27 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I have comp 828-16s in a 76 model 360 block. They are close but no grinding was needed. I did need to tube the block though because they were uncovering the oil holes.
68 Barracuda Formula S 340
[Re: DARTH V8Я]
#2075228
05/17/16 05:10 PM
05/17/16 05:10 PM
DARTH V8Я
Its a TRAP!
All righty I like the idea of 11:1 on pump gas with iron heads. Nothing like smoking aluminum headed BBC's with an iron headed engine.
[Re: DARTH V8Я]
#2075256
05/17/16 06:02 PM
05/17/16 06:02 PM
madscientist
Washington
All righty I like the idea of 11:1 on pump gas with iron heads. Nothing like smoking aluminum headed BBC's with an iron headed engine. I haven't got it in the car yet. It's on the run in stand now and runs, just dealing with a pissy carb right now. Was going to dyno it but I'm just burning out in the deal and it may go straight to the car.
[Re: DARTH V8Я]
#2075308
05/17/16 08:01 PM
05/17/16 08:01 PM
DARTH V8Я
Its a TRAP!
Roller cam? What kind of timing are you running with the iron heads?
[Re: DARTH V8Я]
#2075312
05/17/16 08:11 PM
05/17/16 08:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Roller cam? What kind of timing are you running with the iron heads? With my 416 and W-2 iron heads I am running 10.6 compression and 36* of timing.. its a decent size roller cam 260/270 on a 105 LSA installed on 105.. that with .640/.640 lift... on the street I run 87 octane.. I will run 93 at the track... I get on it pretty good on the street with the 87 and no issues
[Re: DARTH V8Я]
#2075327
05/17/16 08:32 PM
05/17/16 08:32 PM
madscientist
Washington
Roller cam? What kind of timing are you running with the iron heads? SFT with 255 @ .050 with .620 lift gross 105 LSA installed on a 105 ICL and I'm locked out at 35* total.
[Re: DARTH V8Я]
#2075567
05/18/16 01:47 AM
05/18/16 01:47 AM
DARTH V8Я
Its a TRAP!
Mr P.. given her on the street 10.6 & 87 oct? Are those W2 chambers that good?
Thanks for the info mad!
[Re: DARTH V8Я]
#2075682
05/18/16 10:23 AM
05/18/16 10:23 AM
MR_P_BODY
Thanks for the info mad! They arent bad.. but I also have a .039 quench which is a help... I also touch up the chambers so there isnt any hot spots.. that was real quick with a tootsie roll ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: J_BODY]
#2075754
05/18/16 12:06 PM
05/18/16 12:06 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal. I'm hearing ya. I was sure w/iron heads that there would have to be a quench dome.
[img] [/img]
[Re: J_BODY]
#2075894
05/18/16 03:27 PM
05/18/16 03:27 PM
DARTH V8Я
Its a TRAP!
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal. No doubt. Just fascinated that P-car Iron heads can go that fast.
