Re: Real world weight loss program and it` cost..........
[Re: cdwmotorsports]
#2079595
05/24/16 10:35 PM
05/24/16 10:35 PM
fullmetaljacket
Plus, who wants a full fuel cell in the car with them when it should/could be outside. I once saw a full fuel exterior tank unhinge and fly across the highway and explode one night at a big $$$ run and thank god it wasn't inside the trunk. It was on a 4 door 65' Nova that was quite fast. Stock mountings can sometimes be stealthier and better than aftermarket placements and the plus side is, that you regain room where you need it in a street car. On a race car, it can mean the reverse but still be a safety factor.
[Re: RMCHRGR]
#2079599
05/24/16 10:40 PM
05/24/16 10:40 PM
fullmetaljacket
Very nice indeed RMCHGR. One look by tech and they'll give you the pass. I'm gonna be all over that Plymouth with my magnifying crystal next time I see it live on the street. Neat is always a welcome both when looking underneath and working underneath. When I get a chance, I'll flick some views of the madness in plumbing underneath with my tank as well. It was very hard work, but well worth it now.
[Re: RMCHRGR]
#2079773
05/25/16 02:12 AM
05/25/16 02:12 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
A fuel cell has it's place for sure but sounds like I made an OK choice on the tank. Even have the trunk board in. No spare though! Would like to find a decent repro trunk mat, last one I got wasn't even remotely close to the original. From the bottom. From the top. You might check the rule book on how much rubber hose is legal
[Re: hemi-itis]
#2079774
05/25/16 02:16 AM
05/25/16 02:16 AM
Thumperdart
State of confusion
A fuel cell has it's place for sure but sounds like I made an OK choice on the tank. Even have the trunk board in. No spare though! Would like to find a decent repro trunk mat, last one I got wasn't even remotely close to the original. From the bottom. From the top. You might check the rule book on how much rubber hose is legal Could be wrong but I don`t think that`s the rubber they speak of........ My bad..............was thinking the bottom pic......
[Re: Thumperdart]
#2079839
05/25/16 08:47 AM
05/25/16 08:47 AM
fullmetaljacket
You guys are funny. RMCHGR, Ultra-lite hose or what ever it's called is legal and super lightweight. Ex$pensive but real durable. I've used it up front by the engine.
[Re: hemi-itis]
#2079874
05/25/16 10:18 AM
05/25/16 10:18 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
You might check the rule book on how much rubber hose is legal Yup, Push-Lok is not "rubber". He's fine
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: hemi-itis]
#2079925
05/25/16 11:46 AM
05/25/16 11:46 AM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
You might check the rule book on how much rubber hose is legal Al, if you are referring to the hose coming from the sump, it's not regular pass car rubber hose, it's super special, hi performance Ricky racer hose. No parts-store worm clamps or cheesy brass fittings, only the best for the Great Pumpkin. You can do the whole car with this stuff, the guy at Etown wouldn't bat an eye, unless he was flirting with you in the tech line and that would be weird. Read below. "High-Quality Hose for the (cheap NY heeb) Cost-Conscious Racer
Russell Twist-Lok is the way to go for the enthusiast looking for a quality performance hose while wanting to save assembly time and money. Twist-Lok hose is ideal for most automotive applications where a stainless steel braided line is not necessary. It features an extruded Chlorinated Polyethylene (CPE) compound inner liner that is compatible with most fluids, reinforced fabric braid for flexibility and positive hose end attachment, and high-quality elastomer cover to resist abrasion. Use Twist-Lok hose with Russell Twist-Lok hose end fittings. Features: Compatible with hydrocarbon and alcohol based fuels, water systems, synthetic lubricants, and additives High-quality elastomer cover Lightweight and excellent flexibility Pressure rated up to 250 psi Suitable for most fuel and oil systems (NOT for power steering use) Use with Russell Twist-Lok Hose Ends Approved by NHRA for use in competition"As for the fill tube connection with the hose, I would say it's D.O.T. type stuff and quite burly. There is very little gap between the tube and the tank inside anyway so it's mostly there to keep things snug. The OE fill tube has a baffle inside with a little tongue sticking out the end. I tried to simulate the original as best as I could. Here's a pic after it was cut and re-shaped... Here's how it looks under the hose. The tubing sections are closer together when bolted down, they pretty much butt together. The angle of the tube coming out the tank is different than the fill tube, hence the need for the hose. Not sure why the guys that make the tank can't clock the angle correctly to match the fill tube but this is the way it it comes. We good?
'71 Duster '72 Challenger '17 Ram 1500
[Re: Thumperdart]
#2080192
05/25/16 07:09 PM
05/25/16 07:09 PM
Triple Threat
Renton Washington
I have the same tank in my Dart, NHRA tech required me to have a rear firewall because of it.
Just something to think about.
[Re: Triple Threat]
#2080231
05/25/16 08:09 PM
05/25/16 08:09 PM
RMCHRGR
Spahn Ranch
Just something to think about. I still have a back seat and no roll bar. (yet) Only thing I can guess as to why you would need a rear firewall would be because it's not an OE part. Other than that, kind of makes no sense but what do I know. Guess we will see when I get to the track this summer.
[Re: fullmetaljacket]
#2080233
05/25/16 08:11 PM
05/25/16 08:11 PM
Triple Threat
Renton Washington
Was it because of the material used to make the tank? This is not in the trunk anymore you know. Not discounting your heads up about NHRA's rules, but I can't see that tank penetrating the trunk floor and coming into the pilots compartment. The area where the rubber connects the filler neck to the tank is considered "In the drivers compartment" Per NHRA. Your experience may vary, I never had an issue until I entered a large NHRA run Divisional event. Not just a weekly bracket race or test and tune, those I had no issue at.
[Re: Triple Threat]
#2080249
05/25/16 08:51 PM
05/25/16 08:51 PM
RMCHRGR
Spahn Ranch
Was it because of the material used to make the tank? This is not in the trunk anymore you know. Not discounting your heads up about NHRA's rules, but I can't see that tank penetrating the trunk floor and coming into the pilots compartment. The area where the rubber connects the filler neck to the tank is considered "In the drivers compartment" Per NHRA. Your experience may vary, I never had an issue until I entered a large NHRA run Divisional event. Not just a weekly bracket race or test and tune, those I had no issue at. There are no divisional meets on my horizon, I'll be lucky if I get the car back out this century so I won't worry about it much. Point taken though, thanks for the heads up. I will be happy if it becomes an issue down the road.
[Re: Triple Threat]
#2082919
05/30/16 05:15 PM
05/30/16 05:15 PM
Posts: 1,472 Martinsville, IN
cdwmotorsports
Martinsville, IN
Was it because of the material used to make the tank? This is not in the trunk anymore you know. Not discounting your heads up about NHRA's rules, but I can't see that tank penetrating the trunk floor and coming into the pilots compartment. The area where the rubber connects the filler neck to the tank is considered "In the drivers compartment" Per NHRA. Your experience may vary, I never had an issue until I entered a large NHRA run Divisional event. Not just a weekly bracket race or test and tune, those I had no issue at. That may be one of the dumbest interpretations of a rule I have ever heard.
eBay-cdwmotorsports
