Carb Jetting with sealed scoop #2074615
05/16/16 05:29 PM
05/16/16 05:29 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
What are you guys doing with jetting when you install a sealed hood scoop?
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Carb Jetting with sealed scoop [Re: 451Guy] #2074623
05/16/16 05:43 PM
05/16/16 05:43 PM
an8sec70cuda Offline
Been a long time, but I think I jetted up 2 sizes all around when I sealed my old 6 pack hood to the carb.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Carb Jetting with sealed scoop [Re: 451Guy] #2074633
05/16/16 05:53 PM
05/16/16 05:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Totally dependent on how the carb is now but something few talk about is the "dirty" or turbulent air that the bowl vents see..........
Re: Carb Jetting with sealed scoop [Re: Thumperdart] #2074748
05/16/16 09:54 PM
05/16/16 09:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its gonna make a difference on how much clearance you
have from the carb to the scoop and weather you have
a ideal entry on the carb
wave
Re: Carb Jetting with sealed scoop [Re: 451Guy] #2075126
05/17/16 02:30 PM
05/17/16 02:30 PM
Mark Whitener Offline
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Carb Jetting with sealed scoop [Re: MR_P_BODY] #2075135
05/17/16 02:39 PM
05/17/16 02:39 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
In the past I ran a 6 pack hood scoop that was not sealed with a 11' x 6' Tall K&N Filter. The filter was about 1/4" from the scoop. I installed a Pro Stock hood scoop. I am running the same filter but now there is an 1" to 1 1/2" above the air cleaner to the scoop. The bottom of the scoop is 5 inches off the hood in an attempt to get into the clean air as per an article that I saw written by Rick Jones. I am curious because every one talks about how there cars picked up when they sealed the scoop. Mine ran identical. Thinking it need to be jetted up. Also the car is horribly inconsistent so I am thinking it is lean.
Thanx 451 Guy
Re: Carb Jetting with sealed scoop [Re: 451Guy] #2075141
05/17/16 02:49 PM
05/17/16 02:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you were peaked out before MOST will need to jet up
a couple of sizes.. I did when I sealed up... on the last
scoop(the one in my sig) I was close enough that it really
didnt change(that was going from a sealed scoop to another
sealed scoop) but the vertical clearance and the ideal entry
that is mounted on the scoop ended up with 1 jet fatter
wave
