King Bearings reviews.
#2073823
05/15/16 01:26 PM
05/15/16 01:26 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I need .001 oversize bearings for my build to get the correct clearances and the only place I can find them is from King. I have never used King bearings before and they recommended the HP series bearings. Anyone else use King good or bad?
The only Carbs I care about are under the hood!
Re: King Bearings reviews.
[Re: Azzkikrcuda]
#2073829
05/15/16 01:33 PM
05/15/16 01:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my last build (416) I used King.. this was the first time for me.. I did have the pan off to fix a leak and I pulled a rod cap to take a look... they looked great ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: mopar dave]
#2073943
05/15/16 05:05 PM
05/15/16 05:05 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
yes, they get great reviews. I just sent back my King rod bearings because they had some taper in them. I had .001+ bearings which gave me .0033 clearance. I'm getting standards in return. I bought them at Nashville engine warehouse for $71. When you say taper do you mean there are more clearances across the bearings at the rod cap lines than straight up and down? If so most Mopar rod bearings (Tom Hoover or Larry Shepard called them thier Delta Wall design bearings ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) are designed to have that feature intentionally ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) It is suppose to provide a extra cushion of oil there to wipe onto the bearing and crankshaft as the motor runs ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#2073947
05/15/16 05:17 PM
05/15/16 05:17 PM
MR_P_BODY
yes, they get great reviews. I just sent back my King rod bearings because they had some taper in them. I had .001+ bearings which gave me .0033 clearance. I'm getting standards in return. I bought them at Nashville engine warehouse for $71. When you say taper do you mean there are more clearances across the bearings at the rod cap lines than straight up and down? If so most Mopar rod bearings (Tom Hoover or Larry Shepard called them thier Delta Wall design bearings ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) ) are designed to have that feature intentionally ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) It is suppose to provide a extra cushion of oil there to wipe onto the bearing and crankshaft as the motor runs I know bearings are thinner at the cap lines... that is where rods pull inward when being stretched... but I was wondering if he is talking across the bearing surface ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Cab_Burge]
#2073948
05/15/16 05:17 PM
05/15/16 05:17 PM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
no, the short measure thru the center section from one side to the other. not from center out to parting line. well, that's nice to know. they did not explain on the phone. thanks
[Re: mopar dave]
#2074030
05/15/16 07:30 PM
05/15/16 07:30 PM
Azzkikrcuda
North Dakota
Good to know, as far as I could find they are the only ones doing .001 oversize bearings for Mopar.
