03 cummins 6 speed issue #2073582
05/14/16 11:09 PM
05/14/16 11:09 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
I have a slight shutter/vibration when taking off pulling a car trailer in second gear.It doesnt do it unless im pulling.Is this a sign the clutch is going out?
Re: 03 cummins 6 speed issue [Re: jst19600] #2073945
05/15/16 05:06 PM
05/15/16 05:06 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The clutch isn't your problem. Could be some hot spots on the flywheel or pressure plate due to slippage but I doubt it since it only does it pulling a load. Does your truck have a 2 piece rear driveshaft? There was a TSB for launch shudder on trucks with a 2 piece driveshaft that recommended checking the rear driveline angle and replacing the tower that supports the carrier bearing. I'm thinking there were several different height towers offered to achieve the correct angle of the rear shaft. Also check your you u joints thoroughly for binding or wear. Especially the rear and middle (if equipped) on the rear driveshaft.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 03 cummins 6 speed issue [Re: jst19600] #2074936
05/17/16 03:36 AM
05/17/16 03:36 AM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
The issue just arose not long ago.I will check the U joints and carrier bearing.Truck has around 157k on it.
