1/4 Fuel Return Line Clamps..... #2073036
05/14/16 01:28 AM
05/14/16 01:28 AM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
What kind of clamps were used on the 1/4 fuel return line in 1970?
Admiration For Multiple Carburetor Vehicles...
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073058
05/14/16 01:54 AM
05/14/16 01:54 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's called a Keystone clamp or a crimp clamp.
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073091
05/14/16 03:55 AM
05/14/16 03:55 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They look like these.
Duster Fuel Line Clamps Reproduction Top Original Bottom (2).jpgDuster Fuel Lines Original With OEM Clamps (2).jpg
Re: 1/4 Fuel Return Line Clamps..... [Re: ScottSmith_Harms] #2073165
05/14/16 11:47 AM
05/14/16 11:47 AM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Ok, so just like the 5/16 and 3/8, but I can't find any 1/4 anywhere?
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073169
05/14/16 11:53 AM
05/14/16 11:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, 1/4" are a problem. I don't know of a source, but they look generally the same as the above examples.
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073204
05/14/16 12:48 PM
05/14/16 12:48 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 1/4 Fuel Return Line Clamps..... [Re: 72roadrunnergtx] #2073208
05/14/16 12:59 PM
05/14/16 12:59 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Perfect, thank you!
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073296
05/14/16 03:16 PM
05/14/16 03:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Auveco # 18439 , an OEM correct one doesn't exist for the 1/4"
one problem.
Originals were yellow zinc.
All the Auveco clamps are clear zinc and wrong markings )
Auveco #s for the others are
18442 for the 5/16" ( clear zinc ,but wrong markings)
18444 is for the 3/8" ( wrong markings and originals were black zinc)
Re: 1/4 Fuel Return Line Clamps..... [Re: Stewpar] #2073515
05/14/16 09:24 PM
05/14/16 09:24 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I just got 1/4 return line yesterday because I need a return for the efi set up. Looks like I need to get these since my car never had a line from factory(383 car)? 1968 super bee
I don't care about anything being factory correct so maybe I can just find something at the parts store. But if I get those clamps, do I need anything else to get it set up. Appreciate any answers for my somewhat dumb/simplistic question smile
Re: 1/4 Fuel Return Line Clamps..... [Re: 68KillerBee] #2073574
05/14/16 10:58 PM
05/14/16 10:58 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Since you are doing EFI you may want to use the fuel line (rubber part) and spiral clamps that are made for EFI. I assume you have a fuel sender or tank that will accept the return line.
