5.9 diesel on "Trucks" #2073159
05/14/16 11:42 AM
05/14/16 11:42 AM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Watched an episode this morning on "trucks" ( one of the auto episodes on "powerblock" which comes on GRIT)....
It was all about the 5.9 cummins diesel, discussing the dowel problem ( and how to fixit), lots of mods and permanently fixing the "5th gear nut problem"...
I do not know much about these, and I do not have a diesel and don't plan on it, but I would think that anyone who has a 5.9 would want to watch this episode... Fairly technical and full of advice for upgrades.....
Re: 5.9 diesel on "Trucks" [Re: minivan] #2073349
05/14/16 04:59 PM
05/14/16 04:59 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is Stacey David the host?
Re: 5.9 diesel on "Trucks" [Re: WO23Coronet] #2073983
05/15/16 06:16 PM
05/15/16 06:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Went through 7, yes SEVEN NV4500's that had the nut problem and 4 of them had the fix... rant
JB Rhinehart, Realist
A-Body's RULE!
Re: 5.9 diesel on "Trucks" [Re: minivan] #2074406
05/16/16 11:05 AM
05/16/16 11:05 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
what is mildly amusing with the dowel pin problem is that everyone forgets about the timing case bolts on the inside that rattle loose and cause the same damage----they need to be pulled-cleaned-and locktited--the tv guys go through the bending of a tab to cover the hole and fail to tell you that the bolt holding that tab can work loose and cause mayhem----dodge fixed it(dowel pin) with a blunt chisel that you stamp an X pattern across the hole----not hard to do....
Re: 5.9 diesel on "Trucks" [Re: WO23Coronet] #2074603
05/16/16 04:59 PM
05/16/16 04:59 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
No, its some younger guys with wild ass hairdos.....
They do a nice job...
Re: 5.9 diesel on "Trucks" [Re: Rhinodart] #2074607
05/16/16 05:04 PM
05/16/16 05:04 PM
Eugene, Oregon
minivan Offline OP
minivan  Offline OP
Eugene, Oregon
Did you weld the nut or replace the mainshaft with a nutless aftermarket???
