Body filler on valve covers?
#2072949
05/13/16 10:50 PM
05/13/16 10:50 PM
Posts: 4,255 Canada
WO23Coronet
Canada
I'm putting some '71 valve covers on my 440. Get them blasted and they're in decent shape but a little wavy on top. Is it possible to use a body filler to smooth them out or would the heat cause issues?
Re: Body filler on valve covers?
[Re: TJP]
#2073041
05/14/16 01:32 AM
05/14/16 01:32 AM
Posts: 20,769 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
[Re: WO23Coronet]
#2073097
05/14/16 05:04 AM
05/14/16 05:04 AM
Posts: 10,168 A Red State
SNK-EYZ
A Red State
If you want to used filler on them to smooth them out "Evercoat Metal 2 Metal" reinforced body filler is a good option.
It won't ever shrink/swell or deform in any way.
[Re: SNK-EYZ]
#2073098
05/14/16 05:31 AM
05/14/16 05:31 AM
Posts: 626 Zombieland
Car Nut
Zombieland
It won't ever shrink/swell or deform in any way. x2
[Re: WO23Coronet]
#2073214
05/14/16 01:07 PM
05/14/16 01:07 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
Not to hijack the thread, but I've been wondering the same about using filler on rust pitted oil pans. The thing that concerns me is heat resistance of the filler material. Evercoat's data sheet shows a "Max Allowable Heat" of 260*F. http://www.finishmaster.com/prod/assets/EVERCOTE889.pdfAssuming the surface is prepped correctly and you do everything according to the instructions, what happens if the surface exceeds that temperature? Does it start to sag, fall off, or ?? How hot do metal valve covers or oil pans get in typical, every day use?
[Re: WO23Coronet]
#2073218
05/14/16 01:11 PM
05/14/16 01:11 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
If a decal lives on a valve cover for 40 years so will bondo.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Belvedere1]
#2073807
05/15/16 12:52 PM
05/15/16 12:52 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i just used plain old Bondo on my Indy heads to cover the logo,many miles.i even had a severe over heat,still hangin in there.SURFACE PREP is key.
[Re: WO23Coronet]
#2074196
05/15/16 10:44 PM
05/15/16 10:44 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Bare steel > Epoxy primer > Bondo > Epoxy primer > Paint.
All that is needed.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: WO23Coronet]
#2074373
05/16/16 08:34 AM
05/16/16 08:34 AM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
j b weld on oil pans works great !!!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
