1970 440-6 4-spd Factory Dual Point Advance Question? #2072142
05/12/16 05:48 PM
05/12/16 05:48 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
On a relatively stock (Mr. Six Pack Cam/mild Port-Polish, Fac Exh Manifolds) what is recommended for the Mechanical and Vacuum advances at least to get started?
Thank you!
-P-
Admiration For Multiple Carburetor Vehicles...
Re: 1970 440-6 4-spd Factory Dual Point Advance Question? [Re: Stewpar] #2072480
05/13/16 10:04 AM
05/13/16 10:04 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Hi Stewpar,
I've copied the distributor advance information from the 70 Service Manual below. If you're looking for a "stock starting point", I would use this as a general guide.
Re: 1970 440-6 4-spd Factory Dual Point Advance Question? [Re: Stewpar] #2074549
05/16/16 03:04 PM
05/16/16 03:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to figure out what the engine wants for initial then go from there, because the stock distributor has a lot of mechanical advance built in.
I would call Bob and ask him his recommendations and go from there , every situation I am pretty sure is unique when it comes to a Mr. 6pk cam ...
Re: 1970 440-6 4-spd Factory Dual Point Advance Question? [Re: JohnRR] #2074774
05/16/16 10:24 PM
05/16/16 10:24 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
I have an email into him up
