Re: What Intake do I need?
[Re: DartDad]
#2071754
05/11/16 11:23 PM
05/11/16 11:23 PM
RapidRobert
that U shaped passage in the middle of each heads' intake face, you absolutely want it to be open
[Re: DartDad]
#2071767
05/11/16 11:41 PM
05/11/16 11:41 PM
RapidRobert
they are "air" barriers to keep the heat riser heated air that flows up in the roundish port in the middle of the "U" that goes across/into/under the bottom of the intake to heat the cool AF mixture, from overheating the 2 ex valves that are on either side of the U (those paired valves are too hot the way it is). EDIT No intake blocks those passages
[Re: DartDad]
#2071852
05/12/16 01:39 AM
05/12/16 01:39 AM
RapidRobert
(1) nothing really, generally not enough debris makes its way up there. (2) Yeah you are correct, an EGR mani would cover em as it lets some of the ex gas in question (from the center roundish port) back into the intake (Exhaust Gas Recirculation)
[Re: DartDad]
#2071986
05/12/16 12:14 PM
05/12/16 12:14 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
What keeps them from getting filled with crap? The stock (EGR) manifold had a passage to cover them. You keeping the engine clean. If the engine gets covered in debris that will not burn up from exhaust heat then it will fill up with crap ...
