Re: Can't get enough caster with offset bushings
[Re: Dartslantsix]
#2071369
05/11/16 11:42 AM
05/11/16 11:42 AM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
Sounds like a "set the toe and let it go" type of shop.
Carl Kessel
[Re: Dartslantsix]
#2071444
05/11/16 02:07 PM
05/11/16 02:07 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Sorry, didn't check this thread for a couple days.
Looking at the print out from the shop, it appears that they currently have me toe-out in the front. I think this is the main problem. I have an appointment for tomorrow and I am going to have them fix the toe. If possible, I am going to have them add in negative camber and not worry as much about the caster.
In the future, this car will need aftermarket UCAs and possibly spacers on the lower ball joint to hit the camber numbers.
Will report back after tomorrow.
Thanks for the responses. The main problem is you have positive camber. You will have very low caster with positive camber. Why did they set positive camber in the first place? Tell them to roll the front all the way out (extended), and the rear all the way in (shortened). And I know you stated you installed the offset bushings correctly - correctly per what? If you do it per the instructions in the box, that is incorrect. The offset bushings should further push the front of the UCA out, and the rear of the UCA in. If all of that is done, you should be 5 to 7* caster and -1.0 to -1.5 camber.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Dartslantsix]
#2071721
05/11/16 10:28 PM
05/11/16 10:28 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Still doesnt make sense, im betting your offset bushings are offset the wrong way. I've gotten more caster than that with stock bushings.
Mopar to the bone!!!
[Re: 72Swinger]
#2071853
05/12/16 01:43 AM
05/12/16 01:43 AM
Uhcoog1
Houston Tx
Still doesnt make sense, im betting your offset bushings are offset the wrong way. I've gotten more caster than that with stock bushings. x2 OP- how about some pics of the cam bolts and bushings as it sits right now?
[Re: Dartslantsix]
#2072164
05/12/16 06:16 PM
05/12/16 06:16 PM
Posts: 2,094 central texas
krautrock
central texas
An update for today. Went back to the shop and they had a different guy do the alignment. Cams ran out of adjustment before he could hit the numbers, but he did get the toe fixed. He was not sure why the other guy set it toe-out.
Car now goes down the road as it should. I'll have to get aftermarket UCAs and possibly use spacers on the LCA to get camber and caster numbers.
Finally numbers: Camber: left +.1 right +.6 Caster: +.9, +1.2 Toe: .07" in, .07" in
It seems this particular car was on the big or small end of their tolerancing back in 1967. I've done a 66 and 65 with the offset bushings and those cars were able to hit 2.5 caster and .5 negative camber.
Thanks for the help! you had more caster in the original alignment setting, i figured you were toe out and that's why it was following grooves and felt twitchy. i would try to get -.25-.5 on the camber, negative camber... as much caster as possible and toed in just a bit. do you have any pics of the adjusters on your UCA's ?
[Re: Dartslantsix]
#2073380
05/14/16 06:08 PM
05/14/16 06:08 PM
72Swinger
Nebraska
Another thing is how retarded the specs are for our cars in these new "hi-tech" machines. Basically if you can hit 1 degree in any of the adjustments you're in the green and can tell the customer its in "spec".
[Re: Dartslantsix]
#2073883
05/15/16 03:37 PM
05/15/16 03:37 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
You can't just "set the toe and let it go"?
*sarcasm*
I think the next time I do my alignment, I'll try setting for max caster, then get the camber as even as possible without affecting the caster and use spacers to get the camber needed like someone else mentioned previously. Think I'll do this with the torsion bars out so that adding spacers would be easier.
Many of the alignment machines I've used have little or no specs in their databases for cars prior to 76.
[Re: Dartslantsix]
#2073995
05/15/16 06:27 PM
05/15/16 06:27 PM
72Swinger
Nebraska
Absolutely ^^^^, with our spindles, caster needs to be in the 8-9+ range to get the MOST contact patch with what we have. Then a camber of -1 to -2 can be all thats needed.
[Re: Dartslantsix]
#2076514
05/19/16 02:54 PM
05/19/16 02:54 PM
Posts: 43 Santa Fe Springs, CA
Jon @ Hotchkis
In a perfect world you want 1-2* more +caster than the spindle's KPI. This will give the inside tire positive camber when steered, but as a consequence with the scrub radii these cars typically have you do get weight jacking. It is all about finding a happy medium and somewhere around +7-9* caster on these cars is about perfect. OP- I agree that we need to see some pictures of your current setup as something sounds fishy. An at-home alignment is easy enough if you can find some flat level ground. A $100 gauge , some straight edges, a couple tape measures, and some sand and you're good to go.
Hotchkis Performance 8633 Sorensen Ave. Santa Fe Springs, CA 90670 Phone: 562-907-7757 x224 Fax: 562-907-7765
Hotchkis Performance East 9075 Highway 152 Mooresville, NC 28115 704-660-3060
