Re: Steering issue on my 84 d150
[Re: 98RAM1500]
#2071033
05/10/16 09:18 PM
05/10/16 09:18 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Seems to me, proper toe in, is supposed to center the wheels, including the steering wheel. That's why there is a toe in, instead of a neutral alignment. These older vehicles are aligned to pull slightly to the left, to compensate for the crown in the road on old two lane highways. Newer vehicles are aligned for a more neutral condition, as most run on 4 lane super highways that are supposed to be flat. Just a guess but, me thinks your alignment shop is not familiar with older vehicles. Bottom line, your wheels should self center to a small extent.
I have mechanical Aptitude. I can screw up anything.
[Re: 98RAM1500]
#2071107
05/10/16 10:53 PM
05/10/16 10:53 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The wide tires will not keep the steering from centering. It only creates a slight drag when steering and not moving.
Caster is what will make a vehicle stable at high speed and will return the wheel to center. Not sure what yours is but I always ask for MAX positive caster when setting alignment. Some idiot thought neg caster was acceptable on muscle era Mopars. Maybe he was not fired yet and set up trucks this way.
If you suspect a column bearing. Split your steering at the coupler to steering box to isolate.
[Re: 98RAM1500]
#2071181
05/11/16 12:16 AM
05/11/16 12:16 AM
Posts: 2,673 Northern MN
1E2C
Northern MN
I figured it out and please don't laugh to hard but I got the center drag link wrong And it was drivable?? I did that a few years ago and while you could mostly drive it straight on pavement, when you hit gravel and turned it just a little it would plow something fierce. Had it to the alignment shop 3 times and they didn't find it, finally quit driving it for a while it was so bad until my son drove his up for a day and with them sitting side by side I could see the problem.
