Re: Traction Bar or Adjustable Pinion Snubber??
[Re: Sport440]
#2070252
05/09/16 06:57 PM
05/09/16 06:57 PM
Posts: 1,014 LEE, MASS
TOMRR
LEE, MASS
Neither, make or buy some clamps for your front spring segments. Id suggest two on the passenger side front, one on the driver side front. And also maybe one each on the rear of the axel on both sides. Thanks for the Reply, Not sure what you mean by Clamps !!! Tom C.
[Re: TOMRR]
#2070272
05/09/16 07:40 PM
05/09/16 07:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Spring clamps http://www.manciniracing.com/caspcl.htmlSimilar to what the factory used.
[Re: Supercuda]
#2070275
05/09/16 07:44 PM
05/09/16 07:44 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Caltracs can be used successfully.
1972 Road Runner
1988 Shelby CSX-T
[Re: Supercuda]
#2070415
05/09/16 11:12 PM
05/09/16 11:12 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
These are not the type of clamps im referring to. The clamps are more like two flat steel bars tightend by bolts that are just beyond the width of the springs. Much more clamping power then these clamps shown in the link. IMO, Clamps or different springs are your fix. 1.El cheapo, clamps. And they can work. 2. More bucs, SS springs 3. Caltracs.
[Re: TOMRR]
#2070560
05/10/16 02:44 AM
05/10/16 02:44 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Caltracs are noisy and much too harsh on a street driven car. They work phenomenally on a smooth race track. Pinion snubbers, when properly adjusted, are way to harsh on a street driven vehicle. I learned this from several decades of experience.
I run slapper bars on my '68 Barracuda with two passenger side Super Stock springs and a 1" lowering block. I had to modify them so they were adjusted properly.
I know, I know, they don't work on Mopars. LOL
I guess the reason I just beat a Hellcat in a flag drop drag race to win the Willow Springs Drags at Spring Fling was my GM 200R4 transmission. My car only had 410 hp at the time too.
The bottom line is they work awesome, ride only slightly stiffer and if you paint them satin black, most people will not tell you how they don't work.
Even Bob Tarozzi, the designer of the Super Stock Springs signed off the set-up of my car. He said they didn't use them because of weight. A pinion snubber is lighter and works great on a smooth track.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: TOMRR]
#2070566
05/10/16 03:13 AM
05/10/16 03:13 AM
Posts: 43,307 Bend,OR USA
Cab_Burge
Wheel hop is really hard on all of the drive train parts, driveshaft, tranny, rear end, U joints axles and so on, not good ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I would replace the existing leaf springs with better ones, what kind of driving do you do mainly to induce wheel hop? Is it a 4 speed or automatic? Pinion snubbers where intorduce on Mopars in 1957 when they lowred the cars closer to the ground to prevent the pinion U joint from hitting the drive line tunnel, not for traction ![work work](/ubbthreads/images/graemlins/custom/work.gif) Fix the problem, don't bandaid it ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
[Re: Cab_Burge]
#2070599
05/10/16 08:34 AM
05/10/16 08:34 AM
TOMRR
LEE, MASS
Wheel hop is really hard on all of the drive train parts, driveshaft, tranny, rear end, U joints axles and so on, not good ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I would replace the existing leaf springs with better ones, what kind of driving do you do mainly to induce wheel hop? Is it a 4 speed or automatic? Pinion snubbers where intorduce on Mopars in 1957 when they lowred the cars closer to the ground to prevent the pinion U joint from hitting the drive line tunnel, not for traction ![work work](/ubbthreads/images/graemlins/custom/work.gif) Fix the problem, don't bandaid it ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) My RR is a 4-Speed with 1970 HP 440 That Dyno at 425 HP and 500 ft.lb torque. It has new hemi Springs on it and what about clamps ??/I do not drag the car and but once in a while would like to spin the tires Mostly just long drives Thanks Tom C.
[Re: Cab_Burge]
#2070602
05/10/16 08:36 AM
05/10/16 08:36 AM
TOMRR
LEE, MASS
Wheel hop is really hard on all of the drive train parts, driveshaft, tranny, rear end, U joints axles and so on, not good ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) I would replace the existing leaf springs with better ones, what kind of driving do you do mainly to induce wheel hop? Is it a 4 speed or automatic? Pinion snubbers where intorduce on Mopars in 1957 when they lowred the cars closer to the ground to prevent the pinion U joint from hitting the drive line tunnel, not for traction ![work work](/ubbthreads/images/graemlins/custom/work.gif) Fix the problem, don't bandaid it ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) My RR is a 4-Speed with 1970 HP 440 That Dyno at 425 HP and 500 ft.lb torque. It has new hemi Springs on it and what about clamps ??/I do not drag the car and but once in a while would like to spin the tires Mostly just long drives Thanks Tom C. ![](http://img.photobucket.com/albums/v504/TOMRR/TOMRR69RR/HPIM4525.jpg)
[Re: jbc426]
#2070764
05/10/16 01:20 PM
05/10/16 01:20 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Pinion snubbers, when properly adjusted, are way to harsh on a street driven vehicle. I learned this from several decades of experience. I'd have to agree here. I added a Pinion Snubber to my 440 4-spd car, and it launched awesome. However, in normal driving it was a major pain. I took it off. I was and still am running factory 440 replacement springs in the car. But, if I wanted to race more, would definitely consider SS springs.
[Re: TOMRR]
#2070787
05/10/16 02:14 PM
05/10/16 02:14 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
My RR is a 4-Speed with 1970 HP 440 That Dyno at 425 HP and 500 ft.lb torque. It has new hemi Springs on it and what about clamps ??/I do not drag the car and but once in a while would like to spin the tires Mostly just long drives Thanks Tom C. Your car looks kind of high in the back for stock hemi springs. Does it perhaps have airshocks on it? If not then are the shocks long enough? If they are airshocks or if the shocks are topping out then you will always have wheel hop.
[Re: Dixie]
#2070794
05/10/16 02:22 PM
05/10/16 02:22 PM
jbc426
West Coast, USA
Pinion snubbers, when properly adjusted, are way to harsh on a street driven vehicle. I learned this from several decades of experience. I'd have to agree here. I added a Pinion Snubber to my 440 4-spd car, and it launched awesome. However, in normal driving it was a major pain. I took it off. I was and still am running factory 440 replacement springs in the car. But, if I wanted to race more, would definitely consider SS springs. I'd like to see someone like AndyF develop a retractable pinion snubber, so it can be deployed or retracted on the fly from inside the car. Something simple and robust that locks in either the extended or retracted position with the flip of a switch. It would need to have some range of adjustability, and when retracted stays out of the path of the suspension movement. It seems like even a cable operated knee-like lever inside the snubber body would work.
[Re: TOMRR]
#2070797
05/10/16 02:27 PM
05/10/16 02:27 PM
Cab_Burge
On your deal buy a good set of leaf springs designed and intended to be used like you want ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I'm not sure if Mopar still offers a set for a 1964 to 1970 B body 4 speed car for all around high performance drinving like you want to do ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I bought a set of the Mopar S.S. road race type leaf springs for my 1966 Coronet, they are the shorter front half length like the A bodys are so the front spring hangars would need to be replaced to keep the rear end in the stock location if you want to do that. I didn't use them as I moved the leaf springs into the rear sub frames and moved the rear end forward two inches, which required reshaping the front fender openings ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I'm sure your leaf springes are worn out so replacing them will help the car a bunch, if you want to try a new set first before adding clamps do that ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) If you want to add the clamps later I use 1/4 thick by 1.0 inch wide flat stock steel and drill 3/8 holes in them on each side and use 3/8 bolts of the proper length for each clamp, I place them on the front half of the spring in every where I can (the tire bulge will, may, hinder using one on each side near the tire bulge ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) ) on the front of each shorter leaf springs to clamp it to the main leaf. Do it with the weight of the car on them, don't jack it up on jack stands with the rear end hanging down ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) You can jack it up and put jack stands under the rear end axle tubes and under the front suspension so it has the weight on the suspension to do that to be able to get under it to work on the car Let us know what you do and the results ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: GomangoCuda]
#2071023
05/10/16 08:54 PM
05/10/16 08:54 PM
TOMRR
LEE, MASS
My RR is a 4-Speed with 1970 HP 440 That Dyno at 425 HP and 500 ft.lb torque. It has new hemi Springs on it and what about clamps ??/I do not drag the car and but once in a while would like to spin the tires Mostly just long drives Thanks Tom C. Your car looks kind of high in the back for stock hemi springs. Does it perhaps have airshocks on it? If not then are the shocks long enough? If they are airshocks or if the shocks are topping out then you will always have wheel hop. No air shocks but I got new shocks from Napa, Any suggestion on a type of shocks to get ??
[Re: TOMRR]
#2071231
05/11/16 01:19 AM
05/11/16 01:19 AM
GomangoCuda
No air shocks but I got new shocks from Napa, Any suggestion on a type of shocks to get ?? Longer and stiffer. I bet they are way too short. Aftermarket HD shocks often are.
[Re: TOMRR]
#2072399
05/13/16 01:05 AM
05/13/16 01:05 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Seems like many options have been laid out for you. There are many ways to resolve this. We can all agree your current leaf springs are too weak. Stiff shocks help too.
The solution with the least drawbacks is a pair of Super Stock springs and a pair of stiff shocks.
A pinion snubber remove ALL suspension travel on the street. As for the clamps, leafs want to slide. You need to clamp these hard enough to force them not to because they want to. When they do slide, the clamps wiĺl hold your car down after suspension compression and hold the car up after suspension compression.
