Page 2 of 3 1 2 3
Re: Can't get enough caster with offset bushings [Re: Kern Dog] #2071244
05/11/16 02:01 AM
05/11/16 02:01 AM
Klamath Falls, Oregon
Dartslantsix Offline OP
Toe out?
I was told that FWD cars use toe out because they are pulling the car. He may have got confused. I'm giving him the benefit of the doubt.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2071304
05/11/16 08:44 AM
05/11/16 08:44 AM
moparx Online content
moparx  Online Content
Originally Posted By Dartslantsix
Toe out?
the FSM for my caravan states toe as -.20 to +.20 with 0.0 as preferred. since i never knew what that degree deal equated to, i just set it at 1/16-1/8 toe in and called it good. i never had any tire wear issues and it tracked down the road good, being able to let go of the steering wheel at 70 on a deserted stretch of interstate and it would track straight and true, not needing any corrective measures to go in a straight line.
beer
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2071369
05/11/16 11:42 AM
05/11/16 11:42 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Sounds like a "set the toe and let it go" type of shop.
Carl Kessel
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2071444
05/11/16 02:07 PM
05/11/16 02:07 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Sorry, didn't check this thread for a couple days.
Looking at the print out from the shop, it appears that they currently have me toe-out in the front. I think this is the main problem. I have an appointment for tomorrow and I am going to have them fix the toe. If possible, I am going to have them add in negative camber and not worry as much about the caster.
In the future, this car will need aftermarket UCAs and possibly spacers on the lower ball joint to hit the camber numbers.
Will report back after tomorrow.
Thanks for the responses.
The main problem is you have positive camber. You will have very low caster with positive camber.
Why did they set positive camber in the first place?
Tell them to roll the front all the way out (extended), and the rear all the way in (shortened). And I know you stated you installed the offset bushings correctly - correctly per what? If you do it per the instructions in the box, that is incorrect. The offset bushings should further push the front of the UCA out, and the rear of the UCA in.
If all of that is done, you should be 5 to 7* caster and -1.0 to -1.5 camber.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Can't get enough caster with offset bushings [Re: moparx] #2071445
05/11/16 02:08 PM
05/11/16 02:08 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
right on. for FWD i go as close to "0" as possible and error on a touch of toe in. With my fishing line and rulers +/- 1/16" and goes down the road strait is good enough. Same for the caravan and barracuda...
My SRT4 was on an alignment rack for an insurance claim and toe measured .1 degree different and camber was only .05 different on the FL than the FR.
Re: Can't get enough caster with offset bushings [Re: Trojmn] #2071711
05/11/16 10:09 PM
05/11/16 10:09 PM
An update for today. Went back to the shop and they had a different guy do the alignment. Cams ran out of adjustment before he could hit the numbers, but he did get the toe fixed. He was not sure why the other guy set it toe-out.
Car now goes down the road as it should. I'll have to get aftermarket UCAs and possibly use spacers on the LCA to get camber and caster numbers.
Finally numbers:
Camber: left +.1 right +.6
Caster: +.9, +1.2
Toe: .07" in, .07" in
It seems this particular car was on the big or small end of their tolerancing back in 1967. I've done a 66 and 65 with the offset bushings and those cars were able to hit 2.5 caster and .5 negative camber.
Thanks for the help!
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2071721
05/11/16 10:28 PM
05/11/16 10:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Still doesnt make sense, im betting your offset bushings are offset the wrong way. I've gotten more caster than that with stock bushings.
Mopar to the bone!!!
Re: Can't get enough caster with offset bushings [Re: 72Swinger] #2071755
05/11/16 11:26 PM
05/11/16 11:26 PM
IN
ahy Offline
ahy  Offline
IN
Glad she is at least running straight. Reasonable caster also though I know you want more.
Re: Can't get enough caster with offset bushings [Re: 72Swinger] #2071853
05/12/16 01:43 AM
05/12/16 01:43 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
x2
OP- how about some pics of the cam bolts and bushings as it sits right now?
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2072164
05/12/16 06:16 PM
05/12/16 06:16 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Finally numbers:
Caster: +.9, +1.2
you had more caster in the original alignment setting, i figured you were toe out and that's why it was following grooves and felt twitchy.
i would try to get -.25-.5 on the camber, negative camber...
as much caster as possible and toed in just a bit.
do you have any pics of the adjusters on your UCA's ?
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2072997
05/14/16 12:01 AM
05/14/16 12:01 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Looking at your numbers your camber is positive! No wonder the caster is low....As the caster increases the camber goes negative where it should be.
Look at your adjustments on your upper arms. The front eccentric should push the arm outward all the way. The rear should wind up in the neutral position, the fat part of eccentric at 6 oclock. This is a rough way of doing a quick setup. If your posted numbers are really whats on the car,its not surprising you arent happy.
It still amazes me how many people are clueless with alignments.
Re: Can't get enough caster with offset bushings [Re: BergmanAutoCraft] #2073055
05/14/16 01:47 AM
05/14/16 01:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
"It still amazes me how many people are clueless with alignments."
The skills to perform a proper alignment on a classic Mopar is not being taught to new techs. The ones with experience with old cars are fading away.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2073106
05/14/16 08:38 AM
05/14/16 08:38 AM
Long Island, NY USA
Long Island, NY USA
I think the problem is people don't understand what the angles mean. This isnt rocket science. We use turn plates, caster/camber gauge and toe bars and do this on a level floor. More time consuming than a real machine but we've never had a problem. 99% of the time not being able to see the thrust hasn't caused us any issues.
I've experimented with specs all the way up to 10 deg caster and neg 2 camber using these tools.
Re: Can't get enough caster with offset bushings [Re: Kern Dog] #2073113
05/14/16 09:03 AM
05/14/16 09:03 AM
and i always say that i "have all the skills necessary to align my vehicle and get the steering wheel crooked". that's why i got all the necessary tools to do the work myself. i got tired taking my stuff to the alignment shop only to return numerous times to get it corrected, plus having to pay out $19.99. and that gives you an idea how long ago that was.
beer
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2073380
05/14/16 06:08 PM
05/14/16 06:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Another thing is how retarded the specs are for our cars in these new "hi-tech" machines. Basically if you can hit 1 degree in any of the adjustments you're in the green and can tell the customer its in "spec".
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2073883
05/15/16 03:37 PM
05/15/16 03:37 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
You can't just "set the toe and let it go"?
*sarcasm*
I think the next time I do my alignment, I'll try setting for max caster, then get the camber as even as possible without affecting the caster and use spacers to get the camber needed like someone else mentioned previously. Think I'll do this with the torsion bars out so that adding spacers would be easier.
Many of the alignment machines I've used have little or no specs in their databases for cars prior to 76.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2073995
05/15/16 06:27 PM
05/15/16 06:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Absolutely ^^^^, with our spindles, caster needs to be in the 8-9+ range to get the MOST contact patch with what we have. Then a camber of -1 to -2 can be all thats needed.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2076317
05/19/16 03:39 AM
05/19/16 03:39 AM
Long Island, NY USA
Long Island, NY USA
I beg to differ with super high caster. I've experimented with many angles and found that super high caster lifts the inside too much on turn in. Im running 4 degrees caster and 1.5 neg camber this weekend at Optima. Car feels neutral and confident on turn in.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2076450
05/19/16 01:02 PM
05/19/16 01:02 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
I set up and built Tom's Valiant that won The SCCA CAM class in SDR last year, and we run 7-9* of caster on all of our cars.
Re: Can't get enough caster with offset bushings [Re: Dartslantsix] #2076514
05/19/16 02:54 PM
05/19/16 02:54 PM
Santa Fe Springs, CA
Jon @ Hotchkis Offline
In a perfect world you want 1-2* more +caster than the spindle's KPI. This will give the inside tire positive camber when steered, but as a consequence with the scrub radii these cars typically have you do get weight jacking. It is all about finding a happy medium and somewhere around +7-9* caster on these cars is about perfect.
OP- I agree that we need to see some pictures of your current setup as something sounds fishy.
An at-home alignment is easy enough if you can find some flat level ground. A $100 gauge , some straight edges, a couple tape measures, and some sand and you're good to go.
Hotchkis Performance
8633 Sorensen Ave.
Santa Fe Springs, CA 90670
Phone: 562-907-7757 x224
Fax: 562-907-7765
Hotchkis Performance East
9075 Highway 152
Mooresville, NC 28115
704-660-3060
Page 2 of 3 1 2 3
