Re: Can't get enough caster with offset bushings
[Re: Dartslantsix]
#2068677
05/07/16 02:10 AM
05/07/16 02:10 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Your rear ride height plays havoc good caster, lower the rear end down and you gain it back. I bet you 3 degree in droppin the rear down 2".
Mopar to the bone!!!
[Re: Dartslantsix]
#2069176
05/08/16 04:19 AM
05/08/16 04:19 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Last year, a buddy took my advice on these Moog bushings. I have used them in several cars to obtain additional caster. My 70 Charger has stock UCAs, reinforced stock LCAs, stock strut rods with poly bushings and was able to get over 4 degrees positive caster with .75 NEG camber. It steers and handles great. My friend has a 71 Road Runner with essentially the same front suspension. I installed the Moog bushings in his car and the alignment guy couldn't get more than 1.5 degrees of caster. I had a hunch about that and after some research, I learned the following: ALL production cars are built with the intention of being the same, yet they are also allowed a small range of tolerance for most everything. If you have ever built an engine, you surely recall there being an acceptable range for the bearing clearance, the piston ring end gaps, etc. Imagine the frame rails, the K member, the UCAs, the strut rods are built to measure within an acceptable range as well. In a perfect world, all cars would have parts right in the middle of every "tolerance" range. It stands to reason that some might have been built where all the parts ended up at one end of the tolerance or the other. This would explain how some cars align so easily while others have trouble. The caster numbers that I have may be the result of "all stars in alignment" as some say. Your car may be one built at the other end of the tolerances. The tubular upper control arms may be what you need.
[Re: BigBlockMopar]
#2069202
05/08/16 09:20 AM
05/08/16 09:20 AM
Posts: 19,456 north of coder
moparx
today's toe is measured in degrees on all the alignment machines i am aware of, and the FSM's calls for this measurement since at least the mid 90's. a typical measurement is around -10*, so if the op says his is at 60* [i forget just what was stated], then i'm inclined to believe that indicates it is toed out, which would cause the twitchyness he is experiencing. the positive camber doesn't help either. i asked at one time what the conversion factor was for toe degrees to inches, but i can't remember if i got an answer, or if i forgot to write it down [which would be the more likely outcome]. just looked. toe was stated at 30* total. that is most likely a toe out setting, unless the "-" was omitted. sorry. "old timers disease" at work........
[Re: Dartslantsix]
#2069220
05/08/16 10:27 AM
05/08/16 10:27 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Can you post a picture of both your bushings in the arms and the cam bolts as aligned?
I've had an alignment guy tell me he couldn't get the numbers I wanted. I had to tell him how to do it.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Dartslantsix]
#2069553
05/08/16 08:14 PM
05/08/16 08:14 PM
Uhcoog1
Houston Tx
I prefer zero toe 7-8.5 caster -1.5 to -2.5 camber (depending on tires)
[Re: ahy]
#2070033
05/09/16 12:53 PM
05/09/16 12:53 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I did the math on the toe to convert inches to angles. Bottom line 0.3 degrees total toe in would be about 1/16" toe in. Not enough. Suggest you need at least 1/8" or .55 degrees total toe in for stability. .8 degrees would even be OK.
Agree the alignment is suspect. Best with MOPARs is to first set the eccentrics for maximum positive caster ignoring all other measurements. Then check it. Then adjust to dial in some negative caster and get it close side to side. Then set the toe.
Total Toe In Total Angle Deg 0 0.00 1/16 0.28 1/8 0.55 3/16 0.83 1/4 1.10
Using what diameter tire? The diameter will impact this measurement. ok, thanks ! i will put this some place i can reference to in the future. BUT, is this degree measurement in toe IN stated as a "plus" or a "minus" number ? that is still confusing to me. help an old guy out here please !
Again, these aren't universal because of variations in tire diameter. They may get you close but won't be exact due to these variations. IMO, toe is easy enough to set in inches, why do gyrations to convert to degrees unless you are decifering a spec sheet. Positive numbers in toe generally refer to a toe in position. Negatives would be toe out.
[Re: TC@HP2]
#2070185
05/09/16 05:02 PM
05/09/16 05:02 PM
moparx
Again, these aren't universal because of variations in tire diameter. They may get you close but won't be exact due to these variations. IMO, toe is easy enough to set in inches, why do gyrations to convert to degrees unless you are decifering a spec sheet. Positive numbers in toe generally refer to a toe in position. Negatives would be toe out. ok. negative is TOE OUT. why, oh why, did the manufacturers go to degrees ????? i realize tires are the critical thing in this measurement ! one thing i learned is NOW i know what the degree deal is when i have to set my minivan and my wife's concorde. and just for the record, i always try for around 1/16"-3/16" TOE IN for a start point on everything. more on a front steer vehicle than on a rear steer. just my preference.
[Re: Dartslantsix]
#2070514
05/10/16 01:30 AM
05/10/16 01:30 AM
Posts: 372 Kings Beach, CA
tahoechallenge
Kings Beach, CA
Before I installed the Hotchkis upper control arms, I was having trouble getting the positive caster and the negative camber that I wanted. I was able to get the desired specs by installing spacer washers like these: http://www.manciniracing.com/caspki.html You start an alignment by setting ride height, and then set max positive caster with the cams. This is done by moving the rear cam towards the engine and the front cam towards the fender. This results in positive camber as well. The next step is to move the front cam in to get the proper negative caster. When you move the front cam back towards the engine you lose some of the positive caster. The spacer washers give you the proper negative camber without moving the front cam back in. It's a time consuming process... In the end I stepped up to the Hotchkis control arms, and could not be happier.
