Fast leaf spring guys inside
#2069360
05/08/16 02:36 PM
05/08/16 02:36 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Im looking for pointers what have you guys done to get your 60ft down. I'm running caltracs and A body mono leaf ,,,sliders. I'm going to try a stiffer rear segment spring to hopefully eliminate some of the rear end rotation..is it possible to get a sub-1.20 60 foot in N/A out of this setup
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Fast leaf spring guys inside
[Re: WHITEDART]
#2069426
05/08/16 04:53 PM
05/08/16 04:53 PM
Posts: 103 muskegon MI
v cummins
muskegon MI
Im looking for pointers what have you guys done to get your 60ft down. I'm running caltracs and A body mono leaf ,,,sliders. I'm going to try a stiffer rear segment spring to hopefully eliminate some of the rear end rotation..is it possible to get a sub-1.20 60 foot in N/A out of this setup Yes you are on the right track. In top stock a buddy of mine Bill Parris would go 1.19 60 foot in a 9.80 car. fr end
[Re: MR_P_BODY]
#2069457
05/08/16 06:02 PM
05/08/16 06:02 PM
WHITEDART
bean town ....Ca
Wrong thing to do... its your shocks at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar
[Re: WHITEDART]
#2069466
05/08/16 06:15 PM
05/08/16 06:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Wrong thing to do... its your shocks at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar The spring is there to hold up the car.. you dont want 2 opposing forces on the spring.. the shock controls rise .. you might have to move the wheelie bars up higher
[Re: WHITEDART]
#2069469
05/08/16 06:20 PM
05/08/16 06:20 PM
Posts: 608 TN
1DGEMAN
TN
John makes a wheelie bar that acts as a lever and plants the tires harder when it hits.
Real Men shift for themselves
[Re: WHITEDART]
#2069482
05/08/16 06:41 PM
05/08/16 06:41 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I'm not that fast with my 3900 lb brick,but I hope to start tuning my suspension and my high 1.4 down some.Do you guys put much preload in??
[Re: MR_P_BODY]
#2069486
05/08/16 06:46 PM
05/08/16 06:46 PM
v cummins
muskegon MI
Wrong thing to do... its your shocks at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar The spring is there to hold up the car.. you dont want 2 opposing forces on the spring.. the shock controls rise .. you might have to move the wheelie bars up higher The shock controls rise but if you are at the limit at the shock the spring must get stiffer. look at stoping rear end rotating
[Re: v cummins]
#2069490
05/08/16 06:55 PM
05/08/16 06:55 PM
MR_P_BODY
Wrong thing to do... its your shocks at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar The spring is there to hold up the car.. you dont want 2 opposing forces on the spring.. the shock controls rise .. you might have to move the wheelie bars up higher The shock controls rise but if you are at the limit at the shock the spring must get stiffer. look at stoping rear end rotating If your at the limit of the shock you have the wrong shocks.. period... if you put a stronger rear segment on it that pulls down on the body.. which is really lifting the axle.. opposite of what the front segment does
[Re: v cummins]
#2069546
05/08/16 08:04 PM
05/08/16 08:04 PM
WHITEDART
bean town ....Ca
Wrong thing to do... its your shocks at the release of the trans brake the wheelie bar rotates 9 inches. Which at that point is too low to the ground I cannot raise the wheelie bar anymore so hopefully eliminating some of the rotation will stop it from unloading the tire when it plants the wheelie bar The spring is there to hold up the car.. you dont want 2 opposing forces on the spring.. the shock controls rise .. you might have to move the wheelie bars up higher The shock controls rise but if you are at the limit at the shock the spring must get stiffer. look at stoping rear end rotating the wheelie bars are up against the floor of the trunk so going higher is not an option the shock does not control the rear end from rotating... I think you missed the question MR,P are you don't understand what I'm asking. This is a common practice with fast leaf spring cars I was told by caltracs
[Re: WHITEDART]
#2069559
05/08/16 08:22 PM
05/08/16 08:22 PM
MR_P_BODY
Think about it.. what allow the pinion to rotate.. the body going up.. you have pretty much a solid front segment... when the front of the pinion rolls up that turns the rear segment down.. why do you think they unclamp the rears... but do what ever you want
[Re: WHITEDART]
#2069564
05/08/16 08:33 PM
05/08/16 08:33 PM
Posts: 4,457 Washington
madscientist
Washington
I was hoping Monte would chime in but so far nope.
The OP is in DIRE need of a double adjustable shock. Mr P is dead on. The spring only holds the car up and the shock controls the motion of the spring.
Shocks shocks shocks.
[Re: madscientist]
#2069568
05/08/16 08:40 PM
05/08/16 08:40 PM
WHITEDART
bean town ....Ca
I have Double adjustables in all four corners separation and rotation have nothing to do with one another
[Re: WHITEDART]
#2069572
05/08/16 08:45 PM
05/08/16 08:45 PM
MR_P_BODY
I have Double adjustables in all four corners separation and rotation have nothing to do with one another You have caltracs correct.. that turns the front pretty much solid.. the front is moving up which allows the rotation.. if the body didnt lift you would have about zero rotation... but then you wouldnt be applying the pressure on the diff
[Re: WHITEDART]
#2069573
05/08/16 08:47 PM
05/08/16 08:47 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Did you ever look into the Chucky bar at Mandellas?
Brian Hafliger
[Re: Brian Hafliger]
#2069592
05/08/16 09:09 PM
05/08/16 09:09 PM
WHITEDART
bean town ....Ca
Did you ever look into the Chucky bar at Mandellas? yes Phil look at the car in Las Vegas. And had the same recommendation is John Calvert stiffer rear segment and said if I didn't have contracts he would recommend the Chucky bar but being as how I had caltracs they were fine...
#2069651
05/08/16 10:10 PM
05/08/16 10:10 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Did you ever look into the Chucky bar at Mandellas? Have you got a link or something?
[Re: WHITEDART]
#2069678
05/08/16 10:33 PM
05/08/16 10:33 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Front segment goes solid when caltracs bar rotates. Your shocks control how much it separates. I think you need better rear shocks.
Brett Miller W9 cnc'd heads STR Chassis fabraction
