Re: Plazakota
[Re: 67R/T4speeder]
#2074821
05/16/16 11:21 PM
05/16/16 11:21 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Leaving IL on US 36, traveling through MO, KS then moving north in CO to Loveland. Got relatives in Loveland, planning on staying there a few days. Going to tour the Rocky Mountain Nat Park. Then we are heading north through WY on our way to the Black Hills in SD. Planning on spending a day or 2 there, before heading home on US 20 through SD, IA and back to Freeport IL.
16 days, 2200 miles, 7 States, in the coupe! We are intending on staying on two lane highways, and only traveling about 5 hours a day. If there is something we want to see along the way, we intend to stop. We are leaving home May 28. No time restraints other then being home on Monday June 13 for work. Its been 25 years since we have taken a 2 week vacation! Gene
Re: `56 Plazakota
[Re: 67R/T4speeder]
#2075965
05/18/16 04:58 PM
05/18/16 04:58 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before you make a final choice on engine location you might want to install the front end with the core support and check the relative location to the radiator core. Pic below shows my 360 in relation to the firewall and, in this position, the centerline of the water pump shaft is way low in the radiator core.
Re: `56 Plazakota
[Re: 67R/T4speeder]
#2077190
05/20/16 04:34 PM
05/20/16 04:34 PM
John_Kunkel
Rio Linda, CA
The headers are Hedman 79540-6. Passenger side fits without dents but the drivers side is close to the steering shaft so it's dented a little. Wouldn't be necessary if the engine sat higher.
Re: `56 Plazakota
[Re: John_Kunkel]
#2083527
05/31/16 06:32 PM
05/31/16 06:32 PM
Posts: 1,668 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
Are those Magnum port?
Re: `56 Plazakota project
[Re: 67R/T4speeder]
#2109312
07/13/16 12:36 PM
07/13/16 12:36 PM
67R/T4speeder
Caldwell, Idaho
Fitting wheel back on modified shaft, still not in far enough but just resting there to see if I like it.
Re: `56 Plazakota
[Re: 67R/T4speeder]
#2116626
07/24/16 01:40 PM
07/24/16 01:40 PM
67R/T4speeder
Caldwell, Idaho
Here you go, it is 4" c-channel, I wanted it to be bolted in so any fine tuning the body guy needs to they can shim either at sway bar bracket and center bracket like factory. Kinda like how sway bar tuck's inside it.
Thinking of boxing in bracket I welded to c-channel on engine side, what do you think?
