Convert amp gauge to volt meter #2069169
05/08/16 03:54 AM
05/08/16 03:54 AM
Dr Dave Offline OP
Dr Dave  Offline OP
Is there a kit or an easy way to convert the amp gauge to a volt meter in a E-body, NON rallye? Thanks!
Re: Convert amp gauge to volt meter [Re: Dr Dave] #2069172
05/08/16 04:04 AM
05/08/16 04:04 AM
CA
crackedback Offline
crackedback  Offline
CA
Most of the conversions tend to use one of the small sun-pro voltmeters.
Re: Convert amp gauge to volt meter [Re: crackedback] #2069201
05/08/16 09:19 AM
05/08/16 09:19 AM
IN
ahy Offline
ahy  Offline
IN
Yep... usually involves taking the movement out of an accessory gauge and gluing it in. Re-paint gauge face optional. There was a long post on this and a MA article a few years ago. I cheated and had a gauge shop do it.
Re: Convert amp gauge to volt meter [Re: ahy] #2069216
05/08/16 10:22 AM
05/08/16 10:22 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I did mine using a cheapo gauge from pep boys cant tell exactly how many volts but you get the general idea its either under/over from where the pointer is. 14 volts its at the c and over is past and under its before the c.
Re: Convert amp gauge to volt meter [Re: Dr Dave] #2069309
05/08/16 01:03 PM
05/08/16 01:03 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Here you go:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=6158834&Searchpage=1&Main=6157320&Words=Volt+%2Bmeter+Cudajon&topic=&Search=true#Post6158834
Re: Convert amp gauge to volt meter [Re: Cudajon] #2069384
05/08/16 03:26 PM
05/08/16 03:26 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Thanks, but the link won't open
Re: Convert amp gauge to volt meter [Re: Dr Dave] #2069697
05/08/16 10:50 PM
05/08/16 10:50 PM
GA
roadrunninMark Offline
GA
Re: Convert amp gauge to volt meter [Re: Dr Dave] #2069814
05/09/16 01:01 AM
05/09/16 01:01 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Shannon@redlinegaugeworks.com
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
