I want to finish my car and dont know where to start...
#2068670
05/07/16 01:57 AM
05/07/16 01:57 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have too much money in my charger and its not done. I am hoping to find a mentor in southern Idaho or northern Utah who can guide me on finishing my car. I have a basic roller with a Dana 60, home brew front discs, paint is 95% done, still need to do the blackout and I have to replace the lower radiator brace that was screwed up. I have some of the parts to finish but I am lost on how I need to proceed. I know that one part at time is like eating the elephant. I do have some budge and time but some of this is beyond my experience. So if anyone has any advice it would be appreciated. Best regards, Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: I want to finish my car and dont know where to start...
[Re: astjp2]
#2068693
05/07/16 03:09 AM
05/07/16 03:09 AM
astjp2
Utah and Alaska
I know I can do most of the mechanicals easily, it the cosmetic stuff that I have a problem with and I don't do well with interiors. I hate doors and windows, but give me a wire harness and a color chart and I am golden. Tim
[Re: astjp2]
#2068701
05/07/16 04:08 AM
05/07/16 04:08 AM
astjp2
Utah and Alaska
I just did my first 30% off order from year one, ordered a few wiring harnesses, they are supposed to be the best! so I guess I will see. Tim
[Re: astjp2]
#2068717
05/07/16 09:09 AM
05/07/16 09:09 AM
Posts: 1,060 Ball Ground GA
TrueTripleX
Ball Ground GA
Tim, I am not close to you but you are welcome to call me and I will be happy to advise you. I retired from car restoration (Mopars) after 30 years and can probably talk you through your questions or direct you as needed. sharing my years of knowledge is my way to give back to a hobby (love) that took care of me for all those decades. PM me or we can talk. Larry And FYI Rick's assembly sequence above is a great way to go. Rick knows his stuff.
[Re: TrueTripleX]
#2068781
05/07/16 11:45 AM
05/07/16 11:45 AM
RapidRobert
I understand wanting to finish out the roller but would switching gears and getting the drivetrain in & running be a viable plan for you? Hearing the eng roar to life will do wonders for your psyche (you will be pumped!)
[Re: astjp2]
#2068785
05/07/16 11:54 AM
05/07/16 11:54 AM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
I have too much money in my charger and its not done. I am hoping to find a mentor in southern Idaho or northern Utah who can guide me on finishing my car. I have a basic roller with a Dana 60, home brew front discs, paint is 95% done, still need to do the blackout and I have to replace the lower radiator brace that was screwed up. I have some of the parts to finish but I am lost on how I need to proceed. I know that one part at time is like eating the elephant. I do have some budge and time but some of this is beyond my experience. So if anyone has any advice it would be appreciated. Best regards, Tim Think of everything that needs to go together as an assembly I.e. K frame assembly, suspension, engine tranny etc. Your list of what needs to be done is a good start. Here's what I did with my GTS resto. I broke my list down into sections Underneath the car Engine compartment Passenger compartment Trunk compartment Then I broke up my list into those sections. K frame consisted of suspension, brake assembly, engine and tranny. Listed all items and tasks that had anything to do with that assembly. Make notes to your list such as sub assemblies that need to be put together, parts that need to be ordered etc. Underneath the car I listed such things as undercoat, brake lines, fuel lines, gas tank, rear end etc. Passenger compartment I listed things like floor liner, dyno mat, dash, headliner, seats etc And on and on I sat down at the putter and put the list on a spread sheet. As I completed each task I made notes to my list, checked of tasks that were completed and updated the spreadsheet on a continual basis. That way I eliminated sheets of paper that tend to get wet, torn etc. from laying around. If you keep things in sections you'll be able to stay focused, stay organized and see progress on your project.
Abe Lincoln
[Re: astjp2]
#2068877
05/07/16 03:41 PM
05/07/16 03:41 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Putting a car together or taking it apart for rstoration is like doing a airplane Step back, thank hard and make a priority list ,What needs to be done first, whats second and so on I made the mistake of having my 1940 Ford Tudor Sedan painted before all the other fabrication works was done I'll never do that again BTW, I'm like you , I know my strengths and I know my limits. I farm out all the paint and uphlostery also I have a freind who will and can do it all, he is really cheap also To each thier own BTW, PM me if you want,I'mm 300 miles west, maybe we can exchange phone numbers and see if I can be a resource for you or not
[Re: astjp2]
#2069129
05/08/16 01:23 AM
05/08/16 01:23 AM
astjp2
Utah and Alaska
Thanks, for your support, I think that I am going to work on getting the body finished so I can get running gear operational. Fuel lines, wiring, I am going to also going to install a serpentine belt, different upper control arms and a few other options. I will pm everyone who helped and see if I can get a plan together. Tim
[Re: astjp2]
#2069290
05/08/16 12:39 PM
05/08/16 12:39 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Thanks, for your support, I think that I am going to work on getting the body finished so I can get running gear operational. Fuel lines, wiring, I am going to also going to install a serpentine belt, different upper control arms and a few other options. I will pm everyone who helped and see if I can get a plan together. Tim If you bring "everyone" into your build you will have nothing but multiple different opinions.... You need to pick someone who is competent and agrees with the direction you want to take your car.. What you are going through is why you see so many uncompleted cars for sale ( projects) You are at a 50/50 impasse now on going further or selling whether you realize it or not... Been there.. Good luck Pic of what my car looked like as I was going through a divorce ( had to move my car ( and me) and what it looks like now..
[Re: astjp2]
#2069566
05/08/16 08:35 PM
05/08/16 08:35 PM
astjp2
Utah and Alaska
Well I will get a lot of opinions trying to get an idea, but where I get lost is I need screws for "insert trim/part here." I have the assembly book but sometimes I just want a mentor to push me a little and someone who knows Mopar's. I ordered the replacement lower core support sheetmetal bracket that I need to replace because my body guy messed it up. I have to pull the engine to replace it the way I want. While its out, I am going to install the serpentine belt kit from SD concepts and I have a lot of little things to do like move the car to the center of the garage. I also have a lot of tape to remove, there is still some masking tape on it from when it was originally painted. Tim
[Re: astjp2]
#2070166
05/09/16 04:28 PM
05/09/16 04:28 PM
astjp2
Utah and Alaska
The car is a bare roller, but I have to replace that support before I can reinstall the engine and put in a radiator, etc. Ti
[Re: astjp2]
#2070665
05/10/16 11:07 AM
05/10/16 11:07 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The car is a bare roller, but I have to replace that support before I can reinstall the engine and put in a radiator, etc. Ti pick a side and start from there. Back to front, front to back. Or I guess you could do it by item...wiring, suspension, fuel, interior....and so on. Drill the spot welds out of the old support and hang the new one.
[Re: Mr.Yuck]
#2071127
05/10/16 11:23 PM
05/10/16 11:23 PM
astjp2
Utah and Alaska
Support was shipped today, so I will have to get on this when it gets here. Maybe I can start making my fuel lines too. I am going with 1/2" rigid stainless...tim
[Re: astjp2]
#2071173
05/11/16 12:10 AM
05/11/16 12:10 AM
RapidRobert
just me I would want the easier to bend fuel line (I'd never do the hard stuff again)
