Re: Preview my "new" Standard-Port Victor heads (LOOOOONG!)
[Re: sixpackgut]
#2068636
05/07/16 12:57 AM
05/07/16 12:57 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Pretty crazy stock flow #'s.. that's like a 600hp cyl. head.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: sixpackgut]
#2068689
05/07/16 02:33 AM
05/07/16 02:33 AM
BradH
Hate to make you feel bad but those LS3 numbers are way low
I don't feel bad. The Victors are what they are, and should be more than enough head for my POS.
[Re: BradH]
#2068727
05/07/16 09:47 AM
05/07/16 09:47 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I don't feel bad. The Victors are what they are, and should be more than enough head for my POS. Your junk always runs good when it does run. Im sure we lost some good tech advise over the past ?6 years because your car hasnt been running
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#2068854
05/07/16 02:38 PM
05/07/16 02:38 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The plan was to see how doable it was to get these std port Victors to flow an honest 350cfm without making them as big as the Hughes CNC version, which is advertised at 313cc, and had the intake port opening big enough to where Brad ended up having one of his M1 manifolds welded up so he could port match it to the CNC heads. I wanted to do it without making the port opening any bigger. The results posted are from a port with a runner volume of 294cc, and the port opening was left untouched. I also checked the volume of the untouched head and it was 276cc.
It's really a shame that edelbrock decided to fill in the bowls on these heads. At least 1/2 the time spent porting these things was wasted just getting the bowls opened up to a more normal size.
To confirm my observations about the ootb exhaust flow on #7 vs #1, here are the test results:
#7 Lift-------I/E .100---64.2/51.0 .200--126.1/104.1 .300--183.4/143.8 .400--238.8/167.4 .500--281.6/174.8 .550--297.4/176.0 .600--311.8/176.0 .650--302.4/176.0 .700--308.4/176.0 .750--317.5/176.0
[Re: BradH]
#2068857
05/07/16 02:47 PM
05/07/16 02:47 PM
fast68plymouth
So. Burlington, Vt.
For comparison, here are some numbers from an ootb early version head from 2008.
Lift------I/E .100---69.6/51.9 .200--143.8/102.9 .300--194.3/149.9 .400--247.7/184.7 .500--291.8/204.8 .550--311.0/212.6 .600--316.8/216.5 .650--324.5/220.4 .700--330.2/223.1 .750--334.8/224.3
Those early version heads were the best flowing ootb std port heads I've ever seen. With some minor chamber work and some bowl blending they were easily into the 340's. Now to get close to those numbers you have to do some fairly substantial porting. The newer version might be "new", but IMO..... Not even close to "improved". More like a BIG step backwards in terms of being able to buy a decent piece and getting impressive results ootb, or with minimal reworking.
[Re: fast68plymouth]
#2069317
05/08/16 01:15 PM
05/08/16 01:15 PM
BradH
The plan was to see how doable it was to get these std port Victors to flow an honest 350cfm without making them as big as the Hughes CNC version, which is advertised at 313cc, and had the intake port opening big enough to where Brad ended up having one of his M1 manifolds welded up so he could port match it to the CNC heads. I wanted to do it without making the port opening any bigger. The results posted are from a port with a runner volume of 294cc, and the port opening was left untouched. The end result, IMO, is similar to the Chapman 260 cc Stage VIs. I'd passed twice on opportunities to buy the Chapmans years ago, but always thought they had most of "the right stuff" for my type of build.
[Re: BradH]
#2069525
05/08/16 07:35 PM
05/08/16 07:35 PM
fast68plymouth
So. Burlington, Vt.
The Chapmans always escape my memory when talking about BB Mopar heads. Probably because of their relative "unobtainium" status.
they were very nice pieces though.
I'd be pretty surprised if there aren't already more sets of TF BB Mopar heads in the hands of consumers than all the Chapman stage VI's combined.
[Re: BradH]
#2071947
05/12/16 10:49 AM
05/12/16 10:49 AM
BradH
The heads arrived yesterday, but I didn't get a chance to open one of the boxes until this morning. I'll try to take some pics in the next couple of days to show the finished rework of the heads compared to an OOB piece.
Re: Preview my "new" Standard-Port Victor heads - PICS NOW!!!
[Re: BradH]
#2073408
05/14/16 06:49 PM
05/14/16 06:49 PM
BradH
OK, starting to upload pics (4:48 PM). Bear (bare?) with me...
