Re: Piston Deck height vs block deck height?
[Re: Dibbons]
#2068317
05/06/16 02:53 PM
05/06/16 02:53 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
The early higher compression 340s had pistons that come out of the bore about .020"
I have not worked on a trans am 305 but I can say with certainty that it will be difficult to get a reasonably high compression without a piston that is above deck. Head milling will likely be required also.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#2068335
05/06/16 03:21 PM
05/06/16 03:21 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I have not worked on a trans am 305 but I can say with certainty that it will be difficult to get a reasonably high compression without a piston that is above deck. Head milling will likely be required also. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) OP, you may want to look at NHRA web site for the 1968 to 1971 340 piston deck hieghts and cylinder head combuston chamber sizes and use those for figuring the original true compression ratios. I built several 1971 340 NHRA legal "stocker" motors for a customer back in the mid 1990s, using NHRA specs and doing the math those motors had a true 11,5 to 1 compression ratio in bluepring conditions ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) I don't remember the exact specs. now on how high the deck of the pistons where above the cylinder deck, the head gasket thickness came into play so you could raise the pistons up with a thicker head gasket or lower it with a thinner gaskest ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) On your deal your going to have to have a custom set of pistons made to get the exact compression ratio you want. Which is common and normal when building destroke or increase stroked motors, regardless of brand and size ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) IHTHs ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) BTW, Are you aware that when yuo destroke a short stroke motor to start with you will loose all the bottom end power that it had? If not maybe increasing the stroke for your deal might be better for a pump gas street and srip car ![work work](/ubbthreads/images/graemlins/custom/work.gif) The lack of bottom end power was probally one of the main reasons Mopar came out with the 360 C.I. motors in 1971 for a lot of thier cars and trucks, more C.I., more power and torque ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Cab_Burge]
#2068351
05/06/16 03:39 PM
05/06/16 03:39 PM
RapidRobert
I would suggest keep Googling with different approaches/questions especially regarding that class of racing. there's a ton of info out there, most good some bad. Good luck in your quest!
[Re: Dibbons]
#2068389
05/06/16 05:16 PM
05/06/16 05:16 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Head cc 62 domes +10cc bore 4.04" deck clearance 0 stroke 2.96" Piston Compression Height: 1.987
That'll get you 11.22:1 cr. So find a piston that's close or a custom set.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Cab_Burge]
#2068442
05/06/16 06:42 PM
05/06/16 06:42 PM
DARTH V8Я
Its a TRAP!
Definetily not 305 C.I. with a 4.100 bore wih a stock 360 stroke ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) 372 C.I. maybe On a 273 bore.. but where the heck do you find a 273 lol.
[Re: DARTH V8Я]
#2068702
05/07/16 04:19 AM
05/07/16 04:19 AM
Posts: 74 California, United States and ...
Dibbons
That'll get you 11.22:1 cr. So find a piston that's close or a custom set. I did not see the data for the rod length included in the above, 305 rods were 6.25 and stock rods are 6.123. Which rods were used in the above calculations? Thank you.
[Re: Dibbons]
#2068706
05/07/16 05:18 AM
05/07/16 05:18 AM
Dibbons
OK, I see the problem I am facing, it was so basic it flew right over my head. I am trying to squeeze a smaller volume 38.125 cubic inch cylinder of a 305 into the same large 64 cc space (combustion chamber) as the stock 340 42.5 cubic inch cylinder. Naturally, since I start out with a smaller volume, I am not squeezing it down as much, hence the compression works out to about 8.5 to 1 rather than the factory 10.5 to 1.
Now I see in place of the factory flat top piston with valve reliefs, which displaces a negative value of -5cc or -7.5cc, what I will need is a piston with a dome displacement of around 10cc to make up the difference. The only problem with that (in my own mind anyway) is I can only picture the piston smacking the combustion chamber OR, worse yet, the valves smacking the pistons on the way up. The only other alternative I can think of (which is impossible, of course) is a 49cc combustion chamber volume.
I suppose what I really need to see/find is a Mopar 305 Trans AM piston so I know what I am dealing with. I wonder who made/makes those? Maybe what I need is a 340 12.5 to 1 piston, which in my 305 might figure out to be 10.5 to 1 piston?
[Re: Dibbons]
#2068963
05/07/16 06:53 PM
05/07/16 06:53 PM
DARTH V8Я
Its a TRAP!
That'll get you 11.22:1 cr. So find a piston that's close or a custom set. I did not see the data for the rod length included in the above, 305 rods were 6.25 and stock rods are 6.123. Which rods were used in the above calculations? Thank you. 6.123. Becouse your not going to find the 45 year old 305 rods.
[Re: Mcode69]
#2072737
05/13/16 05:09 PM
05/13/16 05:09 PM
Posts: 4,457 Washington
madscientist
Washington
Be aware that the blocks are usually .015" or so higher than what they quote, and the piston height above deck [blueprint spec] as I remember it was .045". So in the real world the early 340's used to have around .030" positive deck height allowing for the extra .015" in block height. That's what I have found when checking piston heights in factory engines as well. This is correct, but that is with a shim gasket. You must ass the extra gasket thickness to the positive deck height. I've run them over .060 out with no problems.
