Re: Needle & Seat Question
[Re: Dragula]
#2068058
05/06/16 12:15 AM
05/06/16 12:15 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I think a .110 good for 650 HP or so. Edit: Don't do it cos I use those for a reason and you can`t just change em at will. Get .130`s and set the pressure to 5 1/2 max..............There's WAY more to those than what they will support hp wise............. You talking GPH? I think the .110's flow 30 gph x 2 thats 60. Not enough I guess?
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Dragula]
#2068065
05/06/16 12:31 AM
05/06/16 12:31 AM
Thumperdart
State of confusion
Don`t do it cos I use those for a reason and you can`t just change em at will. Get .130`s and set the pressure to 5 1/2 max..............There`s WAY more to those than what they will support hp wise.............
[Re: DARTH V8Я]
#2068222
05/06/16 12:14 PM
05/06/16 12:14 PM
Thumperdart
State of confusion
I think a .110 good for 650 HP or so. Edit: Don't do it cos I use those for a reason and you can`t just change em at will. Get .130`s and set the pressure to 5 1/2 max..............There's WAY more to those than what they will support hp wise............. You talking GPH? I think the .110's flow 30 gph x 2 thats 60. Not enough I guess? No, I`m talking about bigger=lower fuel pressures and less aeration in the bowls which means more solid fuel flow and tunes...........I see .110`s in dommys and have to wonder when these builders are going to see the light...............
[Re: Dragula]
#2068223
05/06/16 12:20 PM
05/06/16 12:20 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
What Dom said..Most run WAY to much fuel pressure anyway. Get a good pump and the right pieces and 5-5.5 is PLENTY
[Re: Thumperdart]
#2068231
05/06/16 12:29 PM
05/06/16 12:29 PM
DARTH V8Я
Its a TRAP!
I think a .110 good for 650 HP or so. Edit: Don't do it cos I use those for a reason and you can`t just change em at will. Get .130`s and set the pressure to 5 1/2 max..............There's WAY more to those than what they will support hp wise............. You talking GPH? I think the .110's flow 30 gph x 2 thats 60. Not enough I guess? No, I`m talking about bigger=lower fuel pressures and less aeration in the bowls which means more solid fuel flow and tunes...........I see .110`s in dommys and have to wonder when these builders are going to see the light............... Ahhh gotcha. .130's & 5.5psi. To have it 'pour' into the carb rather than 'sprayed' in with .110 & 7.5psi. Learn something new today, thanks.
[Re: DARTH V8Я]
#2068246
05/06/16 12:47 PM
05/06/16 12:47 PM
Thumperdart
State of confusion
Pretty much and look inside a standard Holley bowl at the "shelf" that the fuel hits and has to overcome then look at a QF entrance and see the smooth funnel which is WAY better. There`s more than meets the eye here and plenty more for ALL of us to learn............
[Re: Al_Alguire]
#2068276
05/06/16 01:41 PM
05/06/16 01:41 PM
Thumperdart
State of confusion
Exactamundo..............
[Re: Dragula]
#2068333
05/06/16 03:20 PM
05/06/16 03:20 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Are the new gen 3 ultras an improvement?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Dragula]
#2068356
05/06/16 03:48 PM
05/06/16 03:48 PM
Al_Alguire
Las Vegas
Well Braswell aint making em.....
[Re: Dragula]
#2068426
05/06/16 06:11 PM
05/06/16 06:11 PM
Posts: 304 Florida
Mark Whitener
The Proform and Quick Fuel bowls are the same, they were a joint venture between Quick Fuel and Dave Braswell. It's my understanding Quick Fuel assembles the carbs sold by Proform.
As far as N&S I use .128's for my gas 4150's, .140's for Dominators and anything E85. Methanol Doms get .164.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: Mark Whitener]
#2068454
05/06/16 07:05 PM
05/06/16 07:05 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
[quote=Mark Whitener]The Proform and Quick Fuel bowls are the same, they were a joint venture between Quick Fuel and Dave Braswell. It's my understanding Quick Fuel assembles the carbs sold by Proform.
cool, good to know. I thought they looked very similar when I purchased them.
[Re: Tig]
#2068507
05/06/16 10:10 PM
05/06/16 10:10 PM
Thumperdart
State of confusion
Are the new gen 3 ultras an improvement? I`ve set up a few w/great results..............
[Re: Al_Alguire]
#2068533
05/06/16 10:34 PM
05/06/16 10:34 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
What Dom said..Most run WAY to much fuel pressure anyway. Get a good pump and the right pieces and 5-5.5 is PLENTY I have a good fuel pump...That is why both my .130 seats are shot...Fuel goes bad, makes the regulator stick closed, pump can't return fuel to the tank...Pump is capable of 70psi if used with efi......It was set at 6lbs.
[Re: Mark Whitener]
#2068618
05/07/16 12:32 AM
05/07/16 12:32 AM
Thumperdart
State of confusion
As far as N&S I use .128's for my gas 4150's, .140's for Dominators and anything E85. Methanol Doms get .164. I may try the .128`s on 4150`s and .140`s on Dommys on my car and see what I find if anything.............. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Dragula]
#2068765
05/07/16 11:03 AM
05/07/16 11:03 AM
Al_Alguire
Las Vegas
The easy way to tell I suppose is loom inside the bowl. If it says POW inc. Its made by Braswell..
