Anyone else try this ? #2067566
05/05/16 12:50 AM
05/05/16 12:50 AM
NM
74fish Offline OP
74fish  Offline OP
NM
I saw on Youtube how you can rejuvenate plastic with a heat gun. I had 2 Burnt Orange kick panels and decided to try it. This was the worst one, it was extremely chalky. and almost unusable.
I heated it and it took a while for to to "gloss" up. I went over it very carefully at first. It started looking pretty good (almost new) on the non chalky part.... I was very surprised however, to see that the chalky areas (although darker than the original) were turning back into plastic. As I went on I got more aggressive. If you go slow and heat each area slowly you can keep warpage to a minimum. I used cold water after and cleaned them up. Pretty satisfied. I still plan on painting them.
Re: Anyone else try this ? [Re: 74fish] #2067573
05/05/16 01:03 AM
05/05/16 01:03 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Impressive, I have a set I need to do this to
eBay-cdwmotorsports
Re: Anyone else try this ? [Re: cdwmotorsports] #2067578
05/05/16 01:14 AM
05/05/16 01:14 AM
that is impressive, thanks for sharing & yes youtube is a goldmine
Re: Anyone else try this ? [Re: 74fish] #2067584
05/05/16 01:33 AM
05/05/16 01:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They are made of Polyethylene, consider it to be very similar to a hard wax in the way it moves with heat. You are simply melting away the degraded areas and leaving a shiny (melted) surface below. You can't make it "turn back into plastic" with heat, but a minimum amount of melting can improve the appearance as you've discovered.
Re: Anyone else try this ? [Re: 74fish] #2067617
05/05/16 08:16 AM
05/05/16 08:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Used to fix scuffs this way at the dealership. To much heat will make a mess. But the right amount works pretty well. After a while you'll be able to judge how much by watching the part.
Doug
