Re: 440 Compression Test Results
[Re: ringo440]
#2066742
05/03/16 09:34 PM
05/03/16 09:34 PM
Posts: 235 ga
ringo440
ga
O.k. talked to the owner of the car today and got a little more history about the car,He was not sure what cam is installed but the guy that built it told him it was a big one. Ask if had any other problems in the past and he told me that he had a electric fuel pump on it and it ran 6psi , which I think was fine, but he said they took it off a couple of weeks ago and put a mechanical pump on because after the car set over night there would be gas on the intake, he said it was like pressure would build up and push it out thottle shaft. Changed to a mechanical pump and no longer has gas on intake, So my thinking is it was probably leaking gas into intake and was washing the cylinder walls down and it got the rings. And that's the cause of the low readings.I am going to try a leak down test the next day or so.
[Re: ringo440]
#2067422
05/04/16 09:23 PM
05/04/16 09:23 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Already changed valley pan gasket. That is was my first move Wrong stagger on rings would be a impossible thing. even if installed with all the gaps lined up with in about 10 revolutions they would no longer be in the same position as the rings constantly turn in the lands. Remember that this is engine that had been running good so IMO this eliminates a improper cam install. A blown or leaky head gasket would not effect all cylinders either.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: ek3]
#2067464
05/04/16 10:21 PM
05/04/16 10:21 PM
RapidRobert
Back in the day the literature frequently referenced "taking it out & blowing the carbon out of it" With the oil burning happening all of a sudden I'd stay after that as some gasket somewhere let loose & I'd find/fix that then onto the low comp. I would do a leakdown tho I'm wondering if fubared oil rings will show definitively on that % & I'm sure it will to some extent but we gotta keep after it with what we got till something develops. As said it might be as simple as low DCR but that is real low numbers. keep us posted!
[Re: ringo440]
#2067517
05/04/16 11:19 PM
05/04/16 11:19 PM
RapidRobert
the grey points more toward fuel enrichment, like you see when your behind someone & they floor it.
[Re: ringo440]
#2067575
05/05/16 01:08 AM
05/05/16 01:08 AM
RapidRobert
Alright, I keep coming back to the valley pan tho not sure about valve stem seals (not convinced but I would check them) & they as the culprit would be more likely to show up on decell (I'm assuming it smokes all the time)
[Re: MoparforLife]
#2067629
05/05/16 09:47 AM
05/05/16 09:47 AM
Posts: 595 Nashville, Tennessee
Tempest
Already changed valley pan gasket. That is was my first move Wrong stagger on rings would be a impossible thing. even if installed with all the gaps lined up with in about 10 revolutions they would no longer be in the same position as the rings constantly turn in the lands. Remember that this is engine that had been running good so IMO this eliminates a improper cam install. A blown or leaky head gasket would not effect all cylinders either. Ditto. It makes us feel better we stagger them when we assemble but you are correct, they turn.
[Re: ringo440]
#2067663
05/05/16 11:12 AM
05/05/16 11:12 AM
Posts: 5,162 CT
GTX MATT
CT
Plan on leak down test tomorrow. when I done the compression test (I have done four so far and got same reading each time).If it was just blue smoke I would say oil.But it seems to be more bluish gray.Vacuum gauge shows 5 to 10 very rapid between the two at idle.bring engine up to about 2000 rpms and vacumn smoothes out at 15. It is like the exhaust valves are not closing all the way.I could see this happen to one head but not both. Leak down test tomorrow we will see. That is a very large jump/swing in vacuum. It sounds to me like it has poorly seating valves, sticky valves, worn guides, worn springs, a burned valve, or some combination of this. Some valve issue IMO. You need to check all 8 too, 1 may be higher or lower and tell us something.
[Re: ringo440]
#2067969
05/05/16 09:31 PM
05/05/16 09:31 PM
Posts: 4,457 Washington
madscientist
Washington
Dead rich. Needs more timing.
[Re: dogdays]
#2068025
05/05/16 11:07 PM
05/05/16 11:07 PM
Posts: 235 ga
ringo440
ga
Photos show plugs darker in photos than they are, I showed plugs because someone asked what they looked like and to show it was not rich. That didn't work out from the photo. I couldn't get the camera down in ports to show the valves so plugs was it.As far the timing goes . When it showed up the timing was one of the first thing I checked. It was set at 42% btc. And the advance was not working. It has MSD distributor and someone set it up with the advance locked out and weights removed. The car started fine the starter spun over fine , Makes me think the cam wasn't degreed in when built. The owner had the weights and spring so reinstalled them and now I have 18 btc at idle and 34 btc at 3000. So much on this engine is over done for the way the guy drives it. Six pack carb setup ,big tube headers,3 inch exhaust,big cam, 5 speed Trans he never turns over 3000 rpms , Drives it a lot on interstate said it turns about 1800 at 70 MPH. With the A/C on
[Re: ringo440]
#2068046
05/05/16 11:48 PM
05/05/16 11:48 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Read the instructions again today,remove one plug installed gauge crank engine over until needlle on gauge no longer moves, write down reading replace plug go to next cylinder and repeat. But just for giggles I removed all plugs and took reading, Got same reading as with the plugs installed, Also checked gauge by installing it in the stock 440 in my Daytona got a reading of 130 only checked one cylinder, but is the readings I felt I should be getting on the Challenger engine This is great feedback. It tells us many things. For one, there are often more than 1 way to get great results. 2, you have a great starter and battery. 3, There will never be a mix up of firing order with your method.
