Rear main seal - Knurled vs smooth sealing area
#2067255
05/04/16 04:42 PM
05/04/16 04:42 PM
Posts: 231 USA
B5496RR
USA
Hello, Trying to tackle a rear main seal leak on my BB. 4.15 Eagle stroker crank with knurling present on the sealing surface. Two local machine shops (two very well known Mopar engine builders) installed a lip seal. Both leaked. I installed a rope seal, it leaks less but still leaks. I'm 100% sure it is leaking from the rear main seal around the crank and not the side seals or anything else on the rear of the engine. Rear seal cap alignment looks good, I dont believe that the rear main seal cap was machined. Please note I'm using PRO-GRAM billet steel main caps and a chenoweth girdle. The rear main seal cap does not contact the rear main studs. I always thought that Knurling = Rope seal Smooth machine surface = Lip seal However, the following link shows differently. Has anyone successfully used a lip seal on a knurled crankshaft with NO leaks?? I'm open to suggestions at this time. http://www.hughesengines.com/Upload/prod...onsJune2006.pdf
Re: Rear main seal - Knurled vs smooth sealing area
[Re: B5496RR]
#2067355
05/04/16 07:20 PM
05/04/16 07:20 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
It's possible the knurl of the crank is a little aggressive for a lip seal and tearing it up?
Current technology of rope seals sucks, the rope seal that comes with basic gasket seals is rock hard compared to the original rope seals made with asbestos. BEST Gasket has a rope seal that is supposed to be the best replacement available, it's a little spendy ... 25 bucks ... and only available thru Best in Cali.
I put one in my friends 383 with stock crank, it seems to be the only thing not leaking ...
[Re: B5496RR]
#2067410
05/04/16 09:08 PM
05/04/16 09:08 PM
Posts: 3,095 Idaho
Runner
Idaho
@Runner, Do you remember if the seal you are using came into direct contact with the Knurling on the crank or does it rest on a smooth portion of the crank?
i didnt verify that the seal came in contact with the knurling but id guess it would about have to? picture
[Re: B5496RR]
#2067488
05/04/16 10:53 PM
05/04/16 10:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think you will fight that leak for a long time unless you pull the crank and put it in a lathe and polish it a bit with some fine paper to knock it down some... I know its a PITA
[Re: ross]
#2067607
05/05/16 04:48 AM
05/05/16 04:48 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have a knurled stroker crank that I Fought with for years until I looked closely at the knurl. It is the wrong direction for a car engine. The crank must have started life in a marine counter rotating engine. Might be worth a look. I have heard of this before also. I agree with Mr P as I would pull the crank and polish the knurl down or off. I cant remember how much knurl was on my 440Source crank but I use steel billet caps and it has not leaked any. Ron
[Re: ross]
#2067652
05/05/16 10:41 AM
05/05/16 10:41 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I have a knurled stroker crank that I Fought with for years until I looked closely at the knurl. It is the wrong direction for a car engine. The crank must have started life in a marine counter rotating engine. Might be worth a look. i had the same situation,if i had hair i would have pulled it out.i used a seal i got from SUPERFORMANCE on my currant build..it is orange crank seal and blue side seal.it leaked when i put it together but after i reinstalled it no more leaks,not one drop.proper inst. is critical.
[Re: dvw]
#2067679
05/05/16 11:55 AM
05/05/16 11:55 AM
Posts: 231 USA
B5496RR
USA
@DVW, I checked the retainer alignment by bolting the retainer in place and checking the retainer to engine block clearance on both sides by eye, I did NOT measure it (I should have, but since the side seals were not leaking I didn't make a measurement).
I believe that you are advising to check this so that the rear main seal is also centered around the crankshaft, is that correct??
The block was line bored because of the caps. How would I determine how much to remove off of the retainer?
@Monte, is this the same direction you were recommending when you stated the retainer is likely the cause?
@All Moparts, If the retainer is the cause of the leak for what ever reason, what seal would use after retainer concern is corrected?
The transmission is out of the car as of now. I really really don't want to pull the engine or the crankshaft out.... But....
[Re: B5496RR]
#2067689
05/05/16 12:20 PM
05/05/16 12:20 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Are you using some form of sealer between the block and retainer mating surface? This is commonly forgotten about. The picture doesn't show any signs that there was sealant in that small area.
[Re: B5496RR]
#2067726
05/05/16 01:23 PM
05/05/16 01:23 PM
Posts: 9,858 MI, usa
dvw
MI, usa
[quote=B5496RR]@DVW, I checked the retainer alignment by bolting the retainer in place and checking the retainer to engine block clearance on both sides by eye, I did NOT measure it (I should have, but since the side seals were not leaking I didn't make a measurement).
The transmission is out of the car as of now. I really really don't want to pull the engine or the crankshaft out.... But.... [/quote It was my concern that the retainer is being forced off center by the bolt holes or the sides not being centered. I checked a Mancini billet retainer that side to side was off by .100"+ Doug p
[Re: B5496RR]
#2067728
05/05/16 01:31 PM
05/05/16 01:31 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Do a search or have someone find the link to thread we just had on this issue. There was a pretty in depth post about how to go about installing the seal and installing retainer, as to NOT having it influence the seal. Will be tough to do in car though. The retainer is FAR from a precision piece and just because it bolts in there and seems centered, means little to nothing. Remember, the seal is what does the sealing to the crank. The retainer should only hold it in the proper place, NOT influence seal in any direction. If it does, it WILL leak. Forget the side seals. Having to drive those in, is asking for a problem. If yours leaks while priming the motor, you likely have a serious alignment issue
