Planning A-518/46RH Swap
#2067070
05/04/16 11:48 AM
05/04/16 11:48 AM
Posts: 163 Florida
Spartan040
I'm really liking the idea of a newer OD transmission for the Challenger build I'm planning, and this setup is going to have somewhere around 600-650 horsepower, maybe a tiny bit more. This is the trans I was looking at: http://www.transdepot.net/46RH-A518-Tran...rH9QaAh9g8P8HAQWhat else do I need to make this work with a 440 that has that kind of power?
Re: Planning A-518/46RH Swap
[Re: Spartan040]
#2067194
05/04/16 03:13 PM
05/04/16 03:13 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a JW Ultrabell for BBM to 727/518 in my shop. It has an expired SFI tag and has never been used. It comes with a 727 case that has had the bell milled off by a Blanchard mill. All the bolts, O'rings, instructions and the JW "Scare Stickers" come with. I don't need it for my racer (not enough power, I am told) and need to pass it on to someone that does. PM me and we can talk price, I can e-mail pictures.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Spartan040]
#2067208
05/04/16 03:23 PM
05/04/16 03:23 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
A better choice for installing an overdrive in a Mopar is to use a 200R4 from Extreme Automatics, a Reid SFI rated bellhousing and a US Cartool crossmember kit. Might as well add the entire chassis stiffening kit while you are in there. It makes a world of difference in how the car feels.
Their 200R4 in a Stage 3 configuration will handle over 1000 hp and over 850 ft lbs of torque. The first gear ratio is a lower 2.76, the overdrive is a .67, it takes significantly less power to spin, is lighter and smaller.
The really nice part is that you can run a high stall converter with a 3 carbon fiber disc lock-up clutch in it. Its the closest thing to a 5 speed automatic going.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2067675
05/05/16 11:47 AM
05/05/16 11:47 AM
Posts: 163 Florida
Spartan040
The really nice part is that you can run a high stall converter with a 3 carbon fiber disc lock-up clutch in it. Its the closest thing to a 5 speed automatic going. Is this a GM transmission? How well will it work with a Mopar engine
[Re: Polarapete]
#2067676
05/05/16 11:48 AM
05/05/16 11:48 AM
Posts: 163 Florida
Spartan040
I have a JW Ultrabell for BBM to 727/518 in my shop. It has an expired SFI tag and has never been used. It comes with a 727 case that has had the bell milled off by a Blanchard mill. All the bolts, O'rings, instructions and the JW "Scare Stickers" come with. I don't need it for my racer (not enough power, I am told) and need to pass it on to someone that does. PM me and we can talk price, I can e-mail pictures. I would take advantage of that but I'm still in the planning phase, nowhere near ready to start buying parts
[Re: Spartan040]
#2067775
05/05/16 03:14 PM
05/05/16 03:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The really nice part is that you can run a high stall converter with a 3 carbon fiber disc lock-up clutch in it. Its the closest thing to a 5 speed automatic going. Is this a GM transmission? How well will it work with a Mopar engine Yes the 200r4 is a GM but works very well and its smaller so it would fit in the tunnel
[Re: Spartan040]
#2067779
05/05/16 03:19 PM
05/05/16 03:19 PM
Polarapete
Graham, WA
I have a JW Ultrabell for BBM to 727/518 in my shop. It has an expired SFI tag and has never been used. It comes with a 727 case that has had the bell milled off by a Blanchard mill. All the bolts, O'rings, instructions and the JW "Scare Stickers" come with. I don't need it for my racer (not enough power, I am told) and need to pass it on to someone that does. PM me and we can talk price, I can e-mail pictures. I would take advantage of that but I'm still in the planning phase, nowhere near ready to start buying parts No problem, I will put it on the transmission side of the web site. There are other things I need for my projects.
[Re: MR_P_BODY]
#2067812
05/05/16 04:14 PM
05/05/16 04:14 PM
Posts: 163 Florida
Spartan040
The really nice part is that you can run a high stall converter with a 3 carbon fiber disc lock-up clutch in it. Its the closest thing to a 5 speed automatic going. Is this a GM transmission? How well will it work with a Mopar engine Yes the 200r4 is a GM but works very well and its smaller so it would fit in the tunnel Cool, I will definitely keep that in mind. Does it require any computer or electrical control? Where would I find the parts necessary for the swap
[Re: Spartan040]
#2067894
05/05/16 07:32 PM
05/05/16 07:32 PM
MR_P_BODY
The really nice part is that you can run a high stall converter with a 3 carbon fiber disc lock-up clutch in it. Its the closest thing to a 5 speed automatic going. Is this a GM transmission? How well will it work with a Mopar engine Yes the 200r4 is a GM but works very well and its smaller so it would fit in the tunnel Cool, I will definitely keep that in mind. Does it require any computer or electrical control? Where would I find the parts necessary for the swap No
[Re: Polarapete]
#2068013
05/05/16 10:50 PM
05/05/16 10:50 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I have a JW Ultrabell for BBM to 727/518 in my shop. It has an expired SFI tag and has never been used. It comes with a 727 case that has had the bell milled off by a Blanchard mill. All the bolts, O'rings, instructions and the JW "Scare Stickers" come with. I don't need it for my racer (not enough power, I am told) and need to pass it on to someone that does. PM me and we can talk price, I can e-mail pictures. The JW ultrabell requires a 10" converter - so make sure to plan that into your budget as well
[Re: moparx]
#2068168
05/06/16 10:32 AM
05/06/16 10:32 AM
MR_P_BODY
The JW ultrabell requires a 10" converter - so make sure to plan that into your budget as well [/quote] i'm guessing smaller than a 10" will work as well ? i'm looking to use a 9 or 9 1/2" [a super tight 8" is a very remote possibility, but i'm not sure anyone makes an 8" that wouldn't overheat a bunch using an od transmission]. [/quote] I'm running a 8" 5000 stall in my 518.. so far its fine EDIT it has 9% slippage in OD... it might be different now after having it worked on
[Re: Spartan040]
#2068619
05/07/16 12:34 AM
05/07/16 12:34 AM
MR_P_BODY
How is the GM transmission superior to the 518 so far as design and functionality go? With some work it can take more power... its lighter and is a smaller unit
[Re: MR_P_BODY]
#2068664
05/07/16 01:43 AM
05/07/16 01:43 AM
Posts: 163 Florida
Spartan040
Sounds good to me, what's required to get it to work with the car besides a proper bell housing
[Re: Spartan040]
#2068761
05/07/16 10:48 AM
05/07/16 10:48 AM
MR_P_BODY
Sounds good to me, what's required to get it to work with the car besides a proper bell housing Fab up a trans mount bracket and a drive shaft.. and the shifter
[Re: Spartan040]
#2068928
05/07/16 05:54 PM
05/07/16 05:54 PM
Posts: 4,212 New York
polyspheric
New York
The 200R4, in the state you need, has almost no original GM parts (much like a Ford 9" differential uses no Ford parts). All the big stuff is replaced with aftermarket - hence the steep price. Yes, it's in those 9 seconds Buick GNX V6 turbo cars, but it's only there temporarily (if you grasp my drift). Unfortunately, it needs adjustment and rebuild more frequently than a 518. The friction area, shaft diameters, bearing sizes etc. are just too small. Except for the clearance problem, the strongest OD automatic is the 4L80E (based on the 1964 Turbo-Hydramatic 400), and even this needs non-GM parts to live. I have a few more remarks on my site: http://victorylibrary.com/mopar/aod.htm
Boffin Emeritus
[Re: Spartan040]
#2068944
05/07/16 06:31 PM
05/07/16 06:31 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How is the GM transmission superior to the 518 so far as design and functionality go? Biggest thing is the OD is internal instead of hanging off the back.
