Isolating failure in hydroboost system - 2002 2500 CTD #2064603
04/30/16 11:49 AM
04/30/16 11:49 AM
Up a holler, down a crick
booger Offline OP
booger  Offline OP
I'm having power brake problems, and am trying to isolate what is wrong - pump, hoses, or hydroboost unit. Basically, from time to time I find myself with the ability to slow down but not stop. I can stand on the brakes, and the truck will stop, but there's a chattering type feel through the pedal, like it's trying to grab but doesn't.
I found instructions on line to troubleshoot the system, but to be honest I followed those instructions and still couldn't figure out what was wrong. Those instructions were asking me to tell if the power assist was there after so many pedal stroke or so much time (IIRC), but I couldn't tell any difference in pedal feel. Even driving down the road when the problem occurs, the pedal feels the same except there's no stopping power. It's not like old vacuum assist systems, where it's like stepping on a rock if the power assist fails.
The truck has always had a "loose belt" sort of sound from the steering during cold weather, but until recently the brakes seemed to be unaffected by that. Last weekend I tried "changing" the PS fluid by cycling two quarts of new fluid through using the turkey baster method. That was no help at all.
I'm trying to avoid throwing money at the problem and replacing parts that are good. Can anyone comment on a good way to figure out what is failed/failing on my 2002 2500 CTD truck?
Thanks in advance for any help,
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065426
05/01/16 07:16 PM
05/01/16 07:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Sounds like an ABS problem. Pull the fuse for the abs pump (light will come on) and see if it still happens.
Most likely a failing wheel speed sensor.
Angry white pureblood male
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065543
05/01/16 10:25 PM
05/01/16 10:25 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
How do you figure that? He would have a light on the dash if there was an issue with the ABS/wheel speed sensor but would most likely still have brakes. Brakes generally don't fail from wheel faulty wheel speed sensors. But just for giggles - is there an ABS light on the dash?
That said, an '02 model year truck would probably only be RWAL. For that system, the speed sensor is on the rear diff.
Obviously the first thing to do is to verify the p.s. fluid level and make sure it's full. You said there was a noise on cold start sometimes? Could be the belt slipping/going away, that's a relatively cheap/easy fix. Maybe try that and see if that helps? Not likely though if it's an intermittent problem but obviously sometimes noises disappear when the truck warms up to operating temp. Same with the pump - if it was the pump or hoses, the problem would most likely be there all the time.
If not the belt, then it's probably the booster. Probably a good idea to replace the hoses if you change it.
Sorry couldn't be more help. Maybe Guitar Jones will chime in, he'll probably know more.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065758
05/02/16 10:15 AM
05/02/16 10:15 AM
booger Offline OP
booger  Offline OP
It does feel like ABS kicking in when it happens, but there are no lights on the dash to go with it. I think. The whole dash could be lit up and I might not notice, since at that point I'm basically looking at what I'm going to hit if I can't get it stopped. It's easy to reproduce so I can sure test it out and look at the dash while it's happening.
The belt is fairly new, and the fluid is full since I just flushed it.
I was able to find internet posts complaining about the cold weather behavior from others that said changing to ATF+4 makes it better. So maybe the pump is OK after all.
I'm about at the point of just replacing everything in the system to be sure whatever is failing is fixed.
FWIW the truck has < 80k miles on it.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065824
05/02/16 12:17 PM
05/02/16 12:17 PM
an8sec70cuda Offline
What does the belt have to do w/ anything? The PS pump isn't run by a belt on the Cummins. Doesn't the PS pump also serve as the hydroboost pump on these trucks?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065829
05/02/16 12:24 PM
05/02/16 12:24 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
If you had a failed sensor or a failure in any part of the ABS system, it would give a code and the ABS light would be on until it was fixed, no if and or buts about that.
Are the service brakes in good condition? Fluid full, clean? Pads/rotors have enough meat on them? I have replaced frozen calipers on older trucks/Jeeps, not totally uncommon. The pulsing you feel could be a warped rotor from overheating. Maybe check the rotor surfaces to see if one is glazed or rusted on one side or looks chewed up in some way. You didn't mention any pulling to one side so that's probably not likely but doesn't cost anything to look. If you're feeling adventurous, maybe get a helper to press the brake pedal while you crack a bleeder or two to see if the fluid gushes out.
If the hydraulic side of the brakes check out, you might ultimately need to have a scan tool put on it. It's an '02 which would be a DRB III. I don't remember what functionality there is (if any) to monitor the brake system on those trucks so I can't say exactly what someone might do but it might help to pinpoint something.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: an8sec70cuda] #2065842
05/02/16 12:43 PM
05/02/16 12:43 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Yep, that's true, my mistake on the belt, did not put it together. I did some reading to edumicate myself and found the link below. Could be a bad vacuum pump/seal behind the P.S. pump. I would bet this is your issue. Bad vacuum pump = no brakes.
Click this link here.
Yes.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065849
05/02/16 12:53 PM
05/02/16 12:53 PM
I had a steering issue a while back and changed the PS pump on mine ('01 2500 CTD). I got a rebuild kit off ebay for the vacuum pump and rebuilt it myself. Not hard to do at all and a heck of a lot cheaper than a new vacuum pump. I wasn't having any issues related to the vacuum pump, but they mount together and to ensure there wasn't an oil leak, I removed both. Figured I might as well rebuild the vacuum pump while I had it off.
CHIP
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: an8sec70cuda] #2065940
05/02/16 02:49 PM
05/02/16 02:49 PM
booger Offline OP
booger  Offline OP
What does the belt have to do w/ anything? Doesn't the PS pump also serve as the hydroboost pump on these trucks?
Ha, that's right, and yes it does.
To the rest of the responses:
The truck is hardly ever driven, the brakes are fine other than this problem. There is no pulsing when the brakes work, only a feeling like an ABS pulsation when I don't have power assist.
I saw posts about the vacuum pump while reading up on how to pull the PS pump, but they weren't clear what the vacuum pump has to do with brakes. The booster is only connected to the PS pump.
I just looked at the booster, it has two high-pressure lines and one return line. One HP line goes to the pump, the other looks like it runs up front to the steering box.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2065955
05/02/16 03:10 PM
05/02/16 03:10 PM
booger Offline OP
booger  Offline OP
^ more reading leads me to believe the vacuum pump is used for HVAC control on the truck. Also if the vacuum seal was going bad, the truck would be spurting oil.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2066656
05/03/16 07:21 PM
05/03/16 07:21 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The PS pump is driven off the vacuum pump. But unless the shafts broke a bad vacuum pump shouldn't affect his ps pump. And that's definitely not an intermittant.
ABS sensors can indeed give false readings and trick the system into an abs stop WITHOUT throwing codes r lights. It's actually pretty common around here, a little saltwater gets into the wiring and throws the resistance off or you get rust jacking that opens up the gap between the sensor and tone ring. You end up with a sensor that does pass the self tests for open or short and still generates readings, but they are off.
You need a scanner that can access the abs data to narrow down which sensors are acting up. But disabling the abs will narrow this down to an abs problem or not.
Knowing how abs works helps here too. The system can (and does) cut the pedal off from what ever wheels the computer thinks is sliding. If he has multiple sensors giving false readings he may very well have no brakes.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2068301
05/06/16 02:17 PM
05/06/16 02:17 PM
booger Offline OP
booger  Offline OP
Thanks ruderunner, that definitely sounds like something I need to investigate this weekend. Luckily I don't have to rely on the truck but I need to get it fixed because there's nothing worse than having a vehicle that isn't usable when you need it.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2068716
05/07/16 09:09 AM
05/07/16 09:09 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
With an ABS capable scanner, you should be able to see which wheel sensor thinks a wheel is locked up. It won't throw a code, because it thinks it is doing its job. I've only done it with Fords, though - I haven't looked at Dodge ABS.
Steve
Someday I'll have another C-body.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: RMCHRGR] #2069285
05/08/16 12:33 PM
05/08/16 12:33 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Your wrong as I've had this happen to my truck... once I pulled the fuse, stops perfectly fine. I have a bad wheel sensor that never once threw a code.
To the OP, pull the abs fuse under the hood and try it. The sound you have is probably a ps pump going bad. If it goes or gets week, you will have a hard time steering and stopping. I've been through it all before. On the vacuum pump, I've done rebuilds and even went new and mine still leaks... nothing left to replace. I recently had the seal blow out in the steering box... guess that's what happens when you run big tires on a heavy front end.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: Silver70] #2069361
05/08/16 02:53 PM
05/08/16 02:53 PM
booger Offline OP
booger  Offline OP
You were all right, I pulled the fuse and went for a drive without it happening once. Normally it happens before I get to the end of the spur I live on (about 100 feet). Now to get the codes pulled and the thing fixed.
Thanks to everybody for the help, you saved me some $$$ for sure wave
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2069607
05/08/16 09:33 PM
05/08/16 09:33 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Dealer and some repair shops have scanners that can get abs data. Local parts store won't. There likely won't be a code, someone will have to watch the live readings.
Sensors themselves are usually easy to change, some can be a bit pricey.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2069885
05/09/16 03:33 AM
05/09/16 03:33 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Missed the cold weather and noise from the pump... mine does the same thing when it's really cold, goes away after it warms up. This is with the new pump. Not sure why, but hasn't been an issue for the past 3 years it has done it.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2069977
05/09/16 11:15 AM
05/09/16 11:15 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I'm surprised but I guess it's possible.
Please reply and let us know what you find if/when it has a scan tool on it. I would ask whoever looks at it to take it for a ride with the scan tool to monitor what happens rather than just deleting codes.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2070012
05/09/16 12:16 PM
05/09/16 12:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
There likely are no codes. You must watch the data to see which sensor is dropping out.
Re: Isolating failure in hydroboost system - 2002 2500 CTD [Re: booger] #2070076
05/09/16 02:22 PM
05/09/16 02:22 PM
booger Offline OP
booger  Offline OP
The truck sits most all the time so I may be able to tell which sensor is bad by looking at it, if it's caused by rust from moisture trapped under the truck. It looks like there's 3, 2 front, one rear center. Even if I just go for broke and replace them all it's still a good bit cheaper than the hydroboost unit.
FWIW I saw at least one thread during my searches saying someone had changed from PS fluid to ATF and the cold weather noise went away.
When I changed mine out I used PS fluid, mostly because it's clear and I was doing the job with a turkey baster hoping the fluid would get clear once I had the old stuff all gone. It never did. I've never had it cause a problem in the cold, the steering's just a little stiffer and noisy.
