Page 88 of 180 1 2 86 87 88 89 90 179 180
Re: Real world weight loss program and it` cost.......... [Re: moparx] #2061934
04/26/16 11:35 AM
04/26/16 11:35 AM
fullmetaljacket Offline
Your welcome DW.
MoparX, I just simply hammered finger grips at the most, two times each while using the original wart holes as a centering guide. The trick was controlling my applied pressure to the swing. Sought of like knowing how much pressure to apply to a hand shake. You don't want to menacingly crush the other guys hand nor do you want to be fleetingly soft.
I guess now thinking about it afterwards, I could have easily fabricated a hammer stop sandwiching the ring on both sides to act as a yield.
The steel round bar was some left over piece from a grommet maker I had laying around which is hardened and the hammer was a rubber mallet. I didn't want to crush the wheel ring or I'd be out a cool whopping $16 dollars.LOL.
I have formed quite a few things using found, discarded shaped objects that serve well as a tool.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2062323
04/26/16 10:35 PM
04/26/16 10:35 PM
Here's the wheel as it was taking preliminary shape as far as the two leg cross bridge now replacing the original tripart bridges. I beveled the ends as to make way for more weld material with the ring. Joe welded both on top and underneath to come up with a solid weld.
Here it sits naked next to its stock sibling at just a tad under 15-3/4" round. Also weighing a tad under 2 Lbs.
The images forthcoming will show how the bridge itself started to take solid shape with add on gusset material to mimic the factory bridge and make it super strong.
I have a tidy workbench, don't I?
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2062421
04/27/16 12:58 AM
04/27/16 12:58 AM
This was a Mickey Mouse way of finding center for the main shaft, but it worked. Necessity is the Mother of..........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2062425
04/27/16 01:00 AM
04/27/16 01:00 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
That's a work of art. How much weight did it save?
Re: Real world weight loss program and it` cost.......... [Re: mopowers] #2062435
04/27/16 01:08 AM
04/27/16 01:08 AM
Thank you.
Just on the wheel itself, saved 3-1/4 lbs.
The horn ring is whole other madness in lard shavings and forming relative to what it weighs which isn't that much. I'll post those when I find 'em.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2064103
04/29/16 04:54 PM
04/29/16 04:54 PM
Here's a close up of one of the side bridge gussets. It does add some rigidity and strength, but it serves more as a visual effect to help mimic the look of an thick injection molded cross bridge. Note how thick the aluminum weld beads are before they get hand filed flush to clean it up and look more eye appealing.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2064105
04/29/16 04:57 PM
04/29/16 04:57 PM
Here's a little tunnel vision to the gussets. Note the drilled injection mold pressure purge hole more or less like the stock wheels.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2064107
04/29/16 04:58 PM
04/29/16 04:58 PM
Here's a rough wheel before going under the file and sand paper.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2064109
04/29/16 05:02 PM
04/29/16 05:02 PM
What a few aggressive and fine files along with grades #100 through #600 sand paper can do with a little patience.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2064135
04/29/16 05:59 PM
04/29/16 05:59 PM
State of confusion
Thumperdart Offline OP
State of confusion
Kick ass man............are you going to paint it?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2064179
04/29/16 07:20 PM
04/29/16 07:20 PM
Already painted and working on the horn ring. Have to get new flicks. The horn ring is the real diamond and a true sculpture in itself. It will be detachable just like the original to expose the center retaining nut for the wheel. Here's an old mock up of the horn ring and wheel looking from underneath.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2064367
04/29/16 11:30 PM
04/29/16 11:30 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Cool! Awesome job man.
I remember when you brought the start of what became the horn ring to that meet out on the Island, what, two summers ago? I believe there is actually a pic in this thread from that day. We all looked at you like, "what the heck izzat?"
Nice to finally see it getting completed!
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2064371
04/29/16 11:40 PM
04/29/16 11:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
FMJ, that is sick
FYI, something was rattling in my dash, the ignition key stuff was rattling. Boom another 10oz of wasted weight
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2064442
04/30/16 01:12 AM
04/30/16 01:12 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Looked for that pic,,,,,,found these,,,,,,,, smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: sixpackgut] #2064484
04/30/16 02:08 AM
04/30/16 02:08 AM
Hemi-itis, his condition is fully blown, but Sixpackgut, your condition has been fully shown. You have walked off the edge of insanity. LOL.
Do you know that a limited run of lightweight aluminum ignition keys were stamped during the 1963 year. I know for sure because Special (K) showed me a couple of sets that he has in his collection. Hemi-itis, you should get a set.
LOL
Thanks fellas.
Wait till I spring out the door jam strikers in T7075 aluminum.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2064887
04/30/16 07:19 PM
04/30/16 07:19 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I have some of the aluminum keys too.
Getting old just means you were smarter than some and luckier than others.
Re: Real world weight loss program and it` cost.......... [Re: dannysbee] #2065148
05/01/16 10:09 AM
05/01/16 10:09 AM
dart1962_440 Offline
Is 63 when the keys switched over? My 62's have aluminum keys with the Forward Look symbol on them.
Re: Real world weight loss program and it` cost.......... [Re: dart1962_440] #2065273
05/01/16 02:23 PM
05/01/16 02:23 PM
IIRC, Special K told me they stopped them in 63'
They are indeed unique cause one can loose them easily because you can't even feel them in your pockets.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2065328
05/01/16 04:13 PM
05/01/16 04:13 PM
AndyF Offline
AndyF  Offline
Is the engine the same as was described in the magazine article? If so, you could save a ton of weight right there without too much work. Some of it would cost some money, but you're spending a lot of money in other places for a lot less weight savings.
Re: Real world weight loss program and it` cost.......... [Re: AndyF] #2065342
05/01/16 04:41 PM
05/01/16 04:41 PM
Andy.
Are you referring to internals such as rods, crank, valves, rockers etc.
As far as the block, I never cut off the mounting ears and or machined the excess stuff off, also I'm staying iron all the way especially with the talk of shift and clearance jumps associated with aluminum.
Do you have any pointers?
Admire your approach to built ups over the years.
