Cam selection help
#2064736
04/30/16 02:55 PM
04/30/16 02:55 PM
Posts: 523 Right here
HP2
Right here
My buddy wants to get rid of the stamped steel and use his old Crane ductile rockers. Then he will need new pushrods so he is considering to swap that ancient Racer Brown .590 hydraulic cam for something more up to date at the same time. 70 Challenger vert, 440" .030 with 10.17 CR, original 906 heads, 1 3/4" headers to 3" h-pipe Flowmaster exhaust, Holley self learning EFI on a high single plane, MSD 6AL and MSD distr., around 3,000 stall and 3.91 SG Runs low 8's on the 1/8 mile with 9" slicks. Drives quite a lot with this car but doesn't care much about fuel economy. He has thoughts on a mechanical cam since next step will probably be a pair of Trick Flow heads.
What cam, and why, would be your choice?
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
Re: Cam selection help
[Re: HP2]
#2064821
04/30/16 05:12 PM
04/30/16 05:12 PM
fast68plymouth
So. Burlington, Vt.
Something like a Comp xs282s is where I'd be looking.
[Re: fast68plymouth]
#2064826
04/30/16 05:24 PM
04/30/16 05:24 PM
Posts: 3,095 Idaho
Runner
Idaho
Something like a Comp xs282s is where I'd be looking. ive bought 2 of these from Dwayne, the first was in my 452ci low deck. i liked it so much that when i put e heads on my daughters 440 i swapped to this cam as well. sounds good at idle, pleasant to drive and overall just runs nice.
[Re: HP2]
#2064833
04/30/16 05:38 PM
04/30/16 05:38 PM
HP2
Right here
Forgot to mention he wants 3-bolt
[Re: HP2]
#2064838
04/30/16 05:44 PM
04/30/16 05:44 PM
HP2
Right here
Any experience with Hughes? They claim all their cams are "Chrysler grinds", is that worth anything? If they take advantage of the larger dia lifters it would be possible to grind steeper ramps
[Re: HP2]
#2064884
04/30/16 07:14 PM
04/30/16 07:14 PM
fast68plymouth
So. Burlington, Vt.
The xs282s is available as a 3 bolt, just change the prefix on the part number from 21 to 23.
[Re: AndyF]
#2064946
04/30/16 09:34 PM
04/30/16 09:34 PM
HP2
Right here
I looked in my cam drawer and I have a 248/252 Comp with .530 lift (1.50 rocker arms) on 113 LSA which would be good for the EFI. I also have a Scotty Brown cam that is similar on 112 LSA. I'll let him know. You might also have pushrods?
