Cast iron R4 blocks #2063144
04/28/16 12:58 AM
04/28/16 12:58 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
P5007151AC, R4, cast iron, for P5-P9 heads. MSRP $2530.00. 7 in the Mopar system
P5007270AC, R4, cast iron, for wedge heads. MSRP $2530.00. 6 in the Mopar system
This is an FYI only, you'll have to do your own research, on what heads to use on each.
Re: Cast iron R4 blocks [Re: Leigh] #2063195
04/28/16 03:19 AM
04/28/16 03:19 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I also posted the part numbers for the remaining 4 59* 9.200 deck R3 blocks in the system in another post....
P4876381AB (1)
P4876791AD (2)
P4876792AD (2)
one part number is Siamese bore, one isn't.
the single 6381AB is the last 48 degree block. 9.0 deck, dry sump only, no motor mounts, steel 4 bolt caps.
...and those R4 wedge blocks have some crazy low deck heights!
Re: Cast iron R4 blocks [Re: Leigh] #2063361
04/28/16 01:45 PM
04/28/16 01:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That's cause those R4's are designed to make big power...Been discussing a possible next project with a certain Corvette owner and it will start with and R4 smile
Re: Cast iron R4 blocks [Re: Al_Alguire] #2063383
04/28/16 02:14 PM
04/28/16 02:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Add a 1.5 in spacer sleeve all 8 cylinders and 4.25 crank 470 Cid P5 that will pull to 8500 rpms. Wow
Matt
Re: Cast iron R4 blocks [Re: Leigh] #2063490
04/28/16 05:21 PM
04/28/16 05:21 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What's the proper way to do a deck spacer? Do you put an undersized bore plate on with an undersized gasket and bore the plate,gasket, and block all together so there's no "lip" for the rings to catch on? Or do you sleeve the block with extra longs sleeves and then put the spacer on around/over too them (having a constant bore with no breaks and the deck plate giving support) and then deck it flat?
Re: Cast iron R4 blocks [Re: WO23Coronet] #2063538
04/28/16 07:16 PM
04/28/16 07:16 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You don't want to run rings over a seam......spacer and long sleeve would be my guess.
Re: Cast iron R4 blocks [Re: tubtar] #2063835
04/29/16 07:03 AM
04/29/16 07:03 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: Cast iron R4 blocks [Re: jcc] #2063889
04/29/16 11:07 AM
04/29/16 11:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...but we're cheap Mopar guys.
Re: Cast iron R4 blocks [Re: J_BODY] #2064034
04/29/16 03:00 PM
04/29/16 03:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah I agree we get a lot of grief about being cheap (we're not) but that is not a real good example, that is a bone stock production 5.3 block produced litteraly by the millions, they pull it off the line and sell it at summit. Summit probably bought thousands at one time. It would be more compareable to a bare bone stock 5.7 hemi block witch by the way is a better block.
The void in the SB mopar world is not the high end blocks but the bracket and hot street guys pushing the limits of stock blocks, a T/A block with better cylinders (siamesed and more consistant) 4 bolt mains and magnum and LA mounts for $1995 would shut up %95 percent of the guys (myself included) belly-aching about the price and availability of aftermarket SBs. Most guys pushing the limit of a stock block don't care if it can be made into a dry sump, we don't care if you can mill the block down an inch shorter, we don't care about multi bolt patterns on the bell, we don't care if there is enough meat to put in 1 inch lifters, or roller cam bearings or "improved oiling" we don't need to pay top dollar for a block that can "do it all" we just want a block that can take more than a stocker can. The new victor head can potentially push 400 CFM on a 4.125 bore, a stock block ain't gonna take 750+HP for long and can't take that bore. The stock oiling can be made to work, the stock cooling can be made to work, the BPE 4.25 crank is awesome but we just need something a little better to put it all in. If I had the money I would get a block made to fit this criteria and be confidant it would fly off the shelf. The advantage a block like this would have is awesome, there is ZERO competetion, in the chevy world the is hundreds of competitors making blocks you would have to compete with, if someone made this block it would be in a market by itself. No you can not charge whatever you want for it, that has been done and failed, you could sell a ton of em if priced fairly. Chevy has several blocks like this for around $1600, slap a $400 premium on us and get er done.
Re: Cast iron R4 blocks [Re: MattW] #2064274
04/29/16 09:38 PM
04/29/16 09:38 PM
dogdays Offline
dogdays  Offline
Here's the quote: "Add a 1.5 in spacer sleeve all 8 cylinders"
This is a whale of a lot of work to be doing.
9" deck is what most smallblock chevies are after they get their decks straightened out. They are 9.025" stock. Siamese SBC blocks can go 4.185" and a Siamese Mopar with its slightly wider bore spacing May be able to go to 4.2 or more. Non-Siamese blocks are limited to maybe 4.100.
A 4" crank with a 6" rod and a 1.0" compression height gets 440 cubic inches using a 4.185 bore. The 434 or 440 smallblock chevy is pretty common in racing circles. That's a lot easier than sleeving all 8 holes.
But I'll never do any of that as there isn't enough money in the old till.
And that 3.78" bore $300 block is good for building a 400hp 327. That's all.
R.
Re: Cast iron R4 blocks [Re: Leigh] #2064288
04/29/16 09:49 PM
04/29/16 09:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The short deck chevy thing got me thinking, I would like the siamese bores, I was thinking of buying into one for that price, still a little high but whatever... then the special un-obtanium intake for a 9 inch deck, no 4.25 crank is going in with any reasonable R/S ratio or pin height, no distributor hole, special timing cover, 60mm cam tunnel adds an aweful lot to the cost of a cheap block.
Re: Cast iron R4 blocks [Re: dogdays] #2064304
04/29/16 10:01 PM
04/29/16 10:01 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
What? The LS? Factory blocks and bottom ends are good to 4-digit horsepower numbers Na/Nitrous. RHS/Warhawk LS aluminum blocks are like 2500hp boosted engines. There's plenty of small bore iron blocks 4.8/5.3 pushing na and boosted pushing 650-1000hp.
thumbs
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Cast iron R4 blocks [Re: DARTH V8Я] #2064334
04/29/16 10:30 PM
04/29/16 10:30 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
thumbs
I know a guy that just built a 5.3 LS with a 88mm turbo in a Mustang and it lasted only a couple passes. Ran a best of 7.07 in the 1/8. It threw a rod out of the block.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Cast iron R4 blocks [Re: DARTH V8Я] #2064335
04/29/16 10:31 PM
04/29/16 10:31 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
thumbs
Re: Cast iron R4 blocks [Re: D-50] #2064337
04/29/16 10:41 PM
04/29/16 10:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The LS blocks I'm seeing have the cam bearing ate out of them. And they weren't high horsepower engines.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cast iron R4 blocks [Re: Leigh] #2064347
04/29/16 10:56 PM
04/29/16 10:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I see quite a few LS 6.0 with spun cam bearings but never a 5.3, don't know what difference but maybe a smaller cam with less spring pressure is doing it?
I highly doubt anyone is makeing 1000 NA hp with a 3.78 bore LS, bet nearly imposible to go over 700 on a max effort deal.
Re: Cast iron R4 blocks [Re: Leigh] #2064348
04/29/16 10:59 PM
04/29/16 10:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
This is the one that impresses me
http://www.summitracing.com/parts/nal-12623967/overview/make/chevrolet
Like to see a Gen III Hemi or LA like this for ONLY DOUBLE the price and I would buy it.
Re: Cast iron R4 blocks [Re: D-50] #2064349
04/29/16 11:06 PM
04/29/16 11:06 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
thumbs
There's a swedish guy that went 6.xx @ 202mph & a couple others with an LSX block too. Held together. plenty running 7's. All staying together. Go figure.
Now that aftermarket needs to get on the ball with mopar blocks. Wouldn't mind paying for a 4.20 bore all aluminum LA block.
Re: Cast iron R4 blocks [Re: HotRodDave] #2064353
04/29/16 11:15 PM
04/29/16 11:15 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Kent Ritter repops the intakes, how many do you want? Used all the time on Chevy 15° motors at the tracks. You don't need a 4.25 crank if your 4.185 or more bore, how big do you want to make your small block. You 440 with a 4" crank and 4.185 bore. I will sell you a 60mm ugl cam for 250.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Cast iron R4 blocks [Re: dogdays] #2064366
04/29/16 11:28 PM
04/29/16 11:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
R.
I never said it would be easy or cheap!!! Lol
I agree with what your saying but let's look at it a different way.
There is enough G3 block out there to fill 98 % of the power level Mopar enthusiasts want.
IMO that hellcat block would take north of 1500 hp. I have no proof just my opinion. 6.4 head 380 cfm is pie.
Want more than that thitek.
Now what I would like to see is the P5 head on a taller block. Nobody would care about no intake or headers because at that level it's all custom.
That head simply rocks. You put together a 500 Cid small block with a head like that and look out.
Now there is another route that you could take and that's the P7.
Ritter has a block and people are putting them together.
Ritters block has some issue but so did the R3. Not making excuses but it's is what it is. And from what I'm hearing it's not casting it's machining. If this is true perhaps he should sell the block not machined to a certain extent. I don't know.
I believe the biggest problem in the Mopar camp is that there is not enough heavy hitters using our junk. Look at the crap people argue about over its not a Mopar block, its not a mopar rear or trans. Yada Yada Yada.
So there are options but people don't want to go there.
Hence no more blocks.
Matt
