Re: Power Nation/Engine Power 512?
[Re: 451Mopar]
#2064287
04/29/16 09:48 PM
04/29/16 09:48 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The "512" that's really a 505, if you go by what they said the bore and stroke is(4.350 x 4.250).
Based on what they said the lift was going to be(mid-.600's as I recall) my guess is it's either going to get higher than stock rocker ratio, or is using a "hydrid" lobe design that's really a solid roller profile that can be run with hyd roller lifters....... Or maybe both.
[Re: fast68plymouth]
#2064358
04/29/16 11:18 PM
04/29/16 11:18 PM
Posts: 4,684 Wichita
GY3
Wichita
Based on what they said the lift was going to be(mid-.600's as I recall) my guess is it's either going to get higher than stock rocker ratio, or is using a "hydrid" lobe design that's really a solid roller profile that can be run with hyd roller lifters....... Or maybe both. Yep. I was yelling at the tv. "IT'S A 505 YOU IDIOTS! Surprising since the older dude is pretty sharp. They skipped a week and run a pig of a 390 Ford this last episode...
[Re: 451Mopar]
#2064556
04/30/16 08:38 AM
04/30/16 08:38 AM
Posts: 1,705 Nebraska
70VcodeCoronetRT
Nebraska
If I remember right it was in the .660 lift range. Didn't catch duration. But I'm old and forgetful too.
[Re: 451Mopar]
#2064721
04/30/16 02:35 PM
04/30/16 02:35 PM
fast68plymouth
So. Burlington, Vt.
Yeh, one of my buddies was mentioning the 390 ford was kind of a mutt for the sum of the parts that were used. They did a 350 Pontiac last year that was also pretty weak.
[Re: 451Mopar]
#2064811
04/30/16 04:58 PM
04/30/16 04:58 PM
fast68plymouth
So. Burlington, Vt.
What would make what I would consider an interesting episode is to take one of these previous underwhelming builds and do some old school hop up mods to get the numbers up. Take that 350 Pontiac, put in a bigger cam, pocket port the heads, different intake manifold, etc. something other than just putting a set of edelbrock heads on it. Maybe rework the stock heads, then install the edelbrock heads afterward to see how much better they are.
[Re: 451Mopar]
#2065183
05/01/16 11:48 AM
05/01/16 11:48 AM
Posts: 1,030 ohio
67mprfan
ohio
I wish my projects only took a 1/2hr to complete.... Can they said was 646/672
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 451Mopar]
#2065271
05/01/16 02:21 PM
05/01/16 02:21 PM
fast68plymouth
So. Burlington, Vt.
While I was watching the show I was thinking a carb would have made more power, but didn't think they'd try it.
The throttle response of the efi didn't look too good.
My guess for why it made less power is the a/f ratio the efi was chasing wasn't optimum for that combo and the carb was just closer to being "right".
It's a different dyno, so a true apples to apples comparison it's not..... But I tested a street 505 last fall. Rpm heads with a little clean up(way less flow than the TF's), xs290s solid cam with 1.5's, 6bbl. Made 645tq/590hp.
I would have thought with the TF heads and intake manifold it would have made closer to 650hp, not to mention the extra .100 lift from the hyd roller they used.
I suppose with the carb on it the numbers were pretty close to what I would have expected, and the difference could just be the dyno.
[Re: GY3]
#2065286
05/01/16 02:48 PM
05/01/16 02:48 PM
Thumperdart
State of confusion
Carb did much better than the FiTech fuel injection.
Thoughts on that? CARBS RULE............Don`t tell Monte that...........
[Re: 451Mopar]
#2065303
05/01/16 03:20 PM
05/01/16 03:20 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I watched that this morning, loved the overhead view of the FiTech at full throttle but it was definitely down on power compared to the carb. I wonder how much tuning was done with the FiTech.
[Re: ProSport]
#2065312
05/01/16 03:35 PM
05/01/16 03:35 PM
Posts: 1,030 ohio
67mprfan
ohio
I watched that this morning, loved the overhead view of the FiTech at full throttle but it was definitely down on power compared to the carb. I wonder how much tuning was done with the FiTech. I don't think they did any tuning just a timing change because they said the EFI was self learning.
