Easiest way to make trunk firewall?
#2064134
04/29/16 05:59 PM
04/29/16 05:59 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have a large sheet of aluminum to make the firewall between my trunk and the passenger compartment. Looking for fabrication hints. I've considered going by a furniture store for a mattress box and making a cardboard template. Or cutting an approximate shape, fastening it either at the bottom or the top, and trimming to fit as it goes. Any tips? thanks.
Re: Easiest way to make trunk firewall?
[Re: NANKET]
#2064431
04/30/16 12:44 AM
04/30/16 12:44 AM
RapidRobert
Yes make a cardboard pattern first. take your time & cut/trim/drill holes in it dead on the way you want it then transfer em so you only have to fit it in there one time
[Re: NANKET]
#2064438
04/30/16 01:02 AM
04/30/16 01:02 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Yes make a cardboard pattern first. Install it from inside the car, not the trunk. that.......
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: crackedback]
#2064457
04/30/16 01:27 AM
04/30/16 01:27 AM
RapidRobert
Construction paper is easier to work with than cardboard. Excellent idea
[Re: DrCharles]
#2064458
04/30/16 01:29 AM
04/30/16 01:29 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Aluminum wont stop a fire, stainless and steel will....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: crackedback]
#2064460
04/30/16 01:34 AM
04/30/16 01:34 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Where do you get it in 30"X 60" sections? Cardboard in that size can be found in almost any homeless camp.
[Re: Kern Dog]
#2064468
04/30/16 01:40 AM
04/30/16 01:40 AM
RapidRobert
that crossed my mind too that he might need to tape/glue several pieces together
[Re: Kern Dog]
#2064483
04/30/16 02:04 AM
04/30/16 02:04 AM
70AARcuda
las vegas
Where do you get it in 30"X 60" sections? Cardboard in that size can be found in almost any homeless camp. bought construction paper from Walmart and taped it together to make it large enough...
Tony
[Re: DrCharles]
#2064595
04/30/16 11:36 AM
04/30/16 11:36 AM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
I use pieces of poster board taped together when I have to make a large pattern. Poster board can be had at 99 cent stores, kmart, wallyworld etc. Very inexpensive. Making it out of stainless instead of aluminum, for fire resistance, may be a toss up as the aluminum should be way more resistant than cardboard and plastic upholstery. But aluminum does melt at a lower temp than stainless. Choices! I wonder if you added some heat deflection material to one side of the sheet it would help on the fire issue plus you may pick up a sound deadening benefit.
Carl Kessel
[Re: dvw]
#2064794
04/30/16 04:30 PM
04/30/16 04:30 PM
RapidRobert
I'd make the pattern so it is tight all around so it is sealed off pretty much completely which I believe is what you are after
[Re: DrCharles]
#2064931
04/30/16 09:00 PM
04/30/16 09:00 PM
DrCharles
West Plains, MO
After some more searching, I found the original cardboard divider! It was a good starting point (to locate the holes for the seat hooks and reproduce the top curve), but since my car is minitubbed I made the aluminum wall 3" wider to sit on the flat front of the wheelhouses rather than taper between them. It'll be easier to seal that way too. So far it's held in place with Cleco clamps, the wiring harness and battery/alternator cables are run through firewall bushings, and I'm trimming the bottom to fit the floor pan before permanently riveting. Unfortunately I can't locate the original package shelf, so will have to draw that long smooth curve another way. Going out of town for a week, more later
