Cam pics I don't think it was a zinc/oil issue
#2063575
04/28/16 08:09 PM
04/28/16 08:09 PM
Posts: 1,451 Martinsville, IN
cdwmotorsports
Martinsville, IN
There is only one lifter and one lobe (#6 cylinder) with any damage, lifter is concaved and lobe has obvious damage. Every other lobe in lifter look great. Only a slight bend to that pushrod. All other pushrods look good as do all of the rocker arms. Any ideas why it would only wipe the one lobe and lifter? Is it at all worth keeping to get repaired and reground?
eBay-cdwmotorsports
Re: Cam pics I don't think it was a zinc/oil issue
[Re: cdwmotorsports]
#2063584
04/28/16 08:18 PM
04/28/16 08:18 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Maybe the lifter was not rotating in it's bore, all the wiped cams I've ever seen only had 1 lifter/lobe gone. You said the push rod was bent? could be an issue some where else in the valve train some bind or clearance issue. check it out good before a new cam is installed and run.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
#2063642
04/28/16 10:33 PM
04/28/16 10:33 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
no it is not worth saving, it is junk.
[Re: Leigh]
#2063644
04/28/16 10:35 PM
04/28/16 10:35 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I install the lifters in the block, mark a line on them with a felt tip and turn the motor over. If one or more don't rotate, I swap positions until they all do. Solid advice right there
When it takes more than a sweet mullet to prove you rule at the trailer park..
#2063645
04/28/16 10:39 PM
04/28/16 10:39 PM
cdwmotorsports
Martinsville, IN
Good tip Leigh I'll do that. If there are oiling issues they have never appeared in the 7 years I drove it. I don't believe the pushrod was rubbing head. Valve springs valves, guides and such were all new when engine was assembled. Pushrods were reused stockers so they will be upgraded this time. To the scrap pile it goes. Thanks for all the suggestions.
eBay-cdwmotorsports
[Re: DARTH V8Я]
#2063760
04/29/16 01:19 AM
04/29/16 01:19 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I install the lifters in the block, mark a line on them with a felt tip and turn the motor over. If one or more don't rotate, I swap positions until they all do. Solid advice right there So that's with no pushrods or spring pressure at all? Turn over - at cranking speed, or just by hand with a ratchet on the damper bolt? thanks.
[Re: DrCharles]
#2063817
04/29/16 04:02 AM
04/29/16 04:02 AM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
I install the lifters in the block, mark a line on them with a felt tip and turn the motor over. If one or more don't rotate, I swap positions until they all do. Solid advice right there So that's with no pushrods or spring pressure at all? Turn over - at cranking speed, or just by hand with a ratchet on the damper bolt? thanks. Just sitting on the cam with light oil, no spring pressure. Turned with ratchet. I got the tip from Jericogtx. I'm not that smart, just ask Jeff!
