Re: M/T 28" W`S.................
[Re: clonestocker]
#2063125
04/28/16 12:29 AM
04/28/16 12:29 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
28x10.5 non w Brad, You excel at Photoshop! v I can steal anyone's photo!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: clonestocker]
#2063133
04/28/16 12:33 AM
04/28/16 12:33 AM
1967dartgt
Hilltown Pa
9.14@145 Dom, It's a small block. Thumbs Up? Don't forget it's NA too....
[Re: 1967dartgt]
#2063137
04/28/16 12:46 AM
04/28/16 12:46 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
9.14@145 Dom, It's a small block. Thumbs Up? Don't forget it's NA too.... MP .590 cam as I recall also....
[Re: jughed]
#2063148
04/28/16 01:02 AM
04/28/16 01:02 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
No E.T. to report... 28 x 13.5 Hoosier QTPs. Moved the rearend back approx. 2" when installing the ladder bars rather than cut on the 1/4s for clearance.(plus i like the stock wheelwell look). Only downside to doing that is slightly less weight on the rears, Looks good man.................
[Re: clonestocker]
#2063149
04/28/16 01:04 AM
04/28/16 01:04 AM
Thumperdart
State of confusion
9.14@145 Dom, It's a small block. Thumbs Up? Damn, some of them puppys straight out fly...........
[Re: Thumperdart]
#2063222
04/28/16 07:43 AM
04/28/16 07:43 AM
Posts: 4,070 Mo.
racerx
Mo.
9.14@145 Dom, It's a small block. Thumbs Up? Damn, some of them puppys straight out fly........... Ain't that the truth.
[Re: Sport440]
#2063305
04/28/16 12:37 PM
04/28/16 12:37 PM
Thumperdart
State of confusion
Current gear/29"tire. 135.5 mph x 4.10 gear x 336/29" tire = 6436.+ 12% vert slip, =7209rpm
Same gear/28"tire. 135.5 mph x 4.10 gear x 336/28" tire = 6666.+ 12% vert slip,=7466rpm Was even wondering if my vert slippage has to do w/the trap r`s and lookin back, I trapped bet 6700-7200 depending...........
[Re: Thumperdart]
#2074111
05/15/16 09:18 PM
05/15/16 09:18 PM
BradH
Same gear/28"tire. 135.5 mph x 4.10 gear x 336/28" tire = 6666.+ 12% vert slip,=7466rpm Was even wondering if my vert slippage has to do w/the trap r`s and lookin back, I trapped bet 6700-7200 depending........... Those calcs don't factor in bias-ply tire growth, so your slippage isn't that high.
[Re: Thumperdart]
#2074115
05/15/16 09:24 PM
05/15/16 09:24 PM
1967dartgt
Hilltown Pa
So when you taking it to the track?
[Re: 1967dartgt]
#2074187
05/15/16 10:32 PM
05/15/16 10:32 PM
Thumperdart
State of confusion
If my friends car isn't ready in time for the Vegas race, he`ll tow me this Thu. for an 1/8th mile jaunt at Irwindale............ Kinda curious what if any gains I`ll see w/all of the changes and weight reduction I`ve made in the last two years.............
[Re: jughed]
#2074204
05/15/16 11:00 PM
05/15/16 11:00 PM
Posts: 2,709 NJ central
Scamp408
NJ central
No E.T. to report... 28 x 13.5 Hoosier QTPs. Moved the rearend back approx. 2" when installing the ladder bars rather than cut on the 1/4s for clearance.(plus i like the stock wheelwell look). Only downside to doing that is slightly less weight on the rears, What's the side to side width on them and what rim size are you using?
[Re: Scamp408]
#2074488
05/16/16 01:12 PM
05/16/16 01:12 PM
Thumperdart
State of confusion
No E.T. to report... 28 x 13.5 Hoosier QTPs. Moved the rearend back approx. 2" when installing the ladder bars rather than cut on the 1/4s for clearance.(plus i like the stock wheelwell look). Only downside to doing that is slightly less weight on the rears, What's the side to side width on them and what rim size are you using? Do you mean section width? Didn't measure it but I`m on a 10" rim and their chart shows something like 13.1 ............
[Re: Thumperdart]
#2074709
05/16/16 08:32 PM
05/16/16 08:32 PM
Posts: 28 Florida
6pkScamp
Hey Dom Don't know what springs your running but I too hated the air shock look of the 70's. I put a set of calverts mono's with the 1" lower spring set up. In actuality it was closer to 2" drop. Had to buy shorter shocks also.
[Re: 6pkScamp]
#2074738
05/16/16 09:22 PM
05/16/16 09:22 PM
Thumperdart
State of confusion
The rear segments are many years old and I went w/the 25" ft. deal a couple years ago so not sure but may hit up calvert about the rear section after I get a few good passes on it as it sits..........
