77 aspen/volare rear bumper #206224
01/27/09 07:36 PM
01/27/09 07:36 PM
phx,az
furyfrank Offline OP
phx,az
need a rear bumper for a 77 aspen found a 79 rear bumper it should fit, or is it different ?
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206225
01/28/09 01:46 AM
01/28/09 01:46 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
With bumper guards or without?
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206226
01/28/09 02:43 AM
01/28/09 02:43 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
77 and 79 bumper shells mount to the inner structure differently. Probably mount to the impact structure the same.
I still have that nice 77 Volare rear bumper you emailed me about
Re: 77 aspen/volare rear bumper [Re: nomore65BelvJim] #206227
01/28/09 06:54 PM
01/28/09 06:54 PM
phx,az
phx,az
looking at both they sure look the same am going to measure both to ease my mine,thanks Jim if yours had the rubber strips and bumper guards I would have bought it.
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206228
01/28/09 08:29 PM
01/28/09 08:29 PM
Kitchener, Ontario, Canada
moparrlz Offline
super street
moparrlz  Offline
super street
Yes they are similar but there is mounting differences. the 76/77 interchange within those years only. Likewise the 78/79 interchange between those years only. I don't know why chrysler did that, but thats what they did. The inner structure was changed in 78.
Fred
Re: 77 aspen/volare rear bumper [Re: moparrlz] #206229
01/28/09 08:59 PM
01/28/09 08:59 PM
phx,az
phx,az
Oh well thanks for the info I guess I will keep looking, what if I changed the inner structure also my buddy is a expert bodyman could he help me change them out,just asking. in one of the post a guy has one but the problem is mine is a SE and has the bumper guards and rub strip and his is plain.
Re: 77 aspen/volare rear bumper [Re: moparrlz] #206230
01/28/09 09:07 PM
01/28/09 09:07 PM
Fred
Fred isnt the spacing of the bolts that mount the bumper assembly to the "impact shock absorbers" the same? I have a 77 rear bumper and the bolt spread is approx. 44-1/2" and 4-1/2". I believe the 79 I parted was the same spread
edit: I know the inner structure changed a lot from 76/77 to 79 but arent the mounting points to the frame the same? I believe the 5mph shocks were the same, but I'm not certain...
Re: 77 aspen/volare rear bumper [Re: nomore65BelvJim] #206231
01/29/09 08:33 PM
01/29/09 08:33 PM
phx,az
phx,az
can anyone tell me the difference ?
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206232
01/30/09 04:56 PM
01/30/09 04:56 PM
Re: 77 aspen/volare rear bumper [Re: nomore65BelvJim] #206233
01/30/09 05:04 PM
01/30/09 05:04 PM
md
mopars4ever Offline
mopars4ever  Offline
md
76-77 are the same and 78-79 are the same according to the part numbers. mopar part number 4000102 76-77 and 4110137 78-79. Whether they will fit I don`t really know but the impact strips and bumper fillers are different part numbers too. Mike
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206234
01/31/09 03:25 PM
01/31/09 03:25 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
'77 front bumper:
See how there's no lip that wraps around the edge? The lip is present in '79s and that is where the inner structure bolts, but that may be on bumpers which have bumpers guards only. I've only checked out '77 and '79 front bumpers in detail.
There should be at least four part numbers for 76-77 and '78-79, each with and without the rub strips...not sure if with bumpers gurads is another part number or not.
I think Jim is correct in stating that the bumper shock absorbers mount the same in all F-bodies- it's the inner structure that's different.
Re: 77 aspen/volare rear bumper [Re: In_The_Pink] #206235
01/31/09 04:22 PM
01/31/09 04:22 PM
phx,az
phx,az
thanks for the replys I will check it out monday to see if it will fit.
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206236
01/31/09 09:40 PM
01/31/09 09:40 PM
md
mopars4ever Offline
mopars4ever  Offline
md
let us know what you find out
Re: 77 aspen/volare rear bumper [Re: mopars4ever] #206237
01/31/09 09:42 PM
01/31/09 09:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
there is four part numbers but for reference I only listed the bumpers with no strips.
Re: 77 aspen/volare rear bumper [Re: nomore65BelvJim] #206238
02/03/09 06:41 PM
02/03/09 06:41 PM
phx,az
phx,az
OK guys here is the info on the bumper the mounting points on the 76/77 are the same as the 78/79. the biggest difference is within the bumper itself, the76/77 has 3/4 in bolts and the 78/79 has 9/16 or 5/8. between the two I beleve that the 76/77 is alot stronger because the bolts are part of the inner structure the78/79 has a seperate piece between the bumper inner structure and the shock absorber. thanks for all the replys.
Re: 77 aspen/volare rear bumper [Re: furyfrank] #206239
02/03/09 08:20 PM
02/03/09 08:20 PM
cool deal Frank...I guess my memory is better than I thought
Re: 77 aspen/volare rear bumper [Re: nomore65BelvJim] #206240
02/04/09 07:39 PM
02/04/09 07:39 PM
phx,az
phx,az
One last thing on the bumper the 76/77 bumper is alot stronger than the 78/79 bumper and weights twice as much as the newer one the mounting points are the same, I guess they saved alot of money and weight on the change.
