Valve adjusting tool?
#2062126
04/26/16 05:19 PM
04/26/16 05:19 PM
Posts: 701 Northern California
lilcuda
Northern California
Does anybody use those valve adjusting tools that have the box wrench/allen wrench combo? If so, do they make it easier to adjust the valves?
The last time I adjusted the valves I used a separate box wrench and an allen wrench and it was a pain.
The rockers are Comp Pro Magnums on a small block if it matters.
Thanks for any input.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
Re: Valve adjusting tool?
[Re: lilcuda]
#2062169
04/26/16 06:49 PM
04/26/16 06:49 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
yes and no, kind of clumsy, handle to high for leverage to tighten need to go back over with flat wrench to make sure locknuts are tight
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 70AARcuda]
#2062292
04/26/16 09:46 PM
04/26/16 09:46 PM
RapidRobert
OT if the spec is 20 tho, if a 21 tho feeler gauge has a slight drag and a 19 tho feeler gauge has no drag then you are within 1 tho of spec. there was on old Hot Rod article decades ago that stated that even a few tho off on the adj makes a significant difference in cam timing. I think a dial indicator being carefull to mount it inline would be the best way to confirm the amt of clearance you do have for that part of the deal
[Re: lilcuda]
#2062355
04/26/16 11:21 PM
04/26/16 11:21 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
The LSM tool with the built in torque wrench is great. I have only used a few of LSMs tools but they have all been top notch.
68 Barracuda Formula S 340
[Re: 70AARcuda]
#2062452
04/27/16 01:43 AM
04/27/16 01:43 AM
lilcuda
Northern California
I saw those on Summit Racing's site. Very nice, but pricey.
[Re: RapidRobert]
#2062455
04/27/16 01:46 AM
04/27/16 01:46 AM
lilcuda
Northern California
OT if the spec is 20 tho, if a 21 tho feeler gauge has a slight drag and a 19 tho feeler gauge has no drag then you are within 1 tho of spec. there was on old Hot Rod article decades ago that stated that even a few tho off on the adj makes a significant difference in cam timing. I think a dial indicator being carefull to mount it inline would be the best way to confirm the amt of clearance you do have for that part of the deal The biggest issue with getting it right on my setup is that it is a Comp XFI hydraulic roller with solid roller lifters. The spec has to be zero lash cold, hopefully opening up to .006" to .008" hot. Not much margin for error.
[Re: lilcuda]
#2062488
04/27/16 02:38 AM
04/27/16 02:38 AM
Posts: 108 Socal
littleVAL
Socal
I was of the opinion that hydraulic cams do not have the same ramp as a solid and will not work with solid lifters. Is that different on a roller.
[Re: lilcuda]
#2062631
04/27/16 12:15 PM
04/27/16 12:15 PM
lilcuda
Northern California
According to Comp Cams, this cam can be run this way as long as the lash is kept tight. The reason it is this way is because the hydraulic roller lifters wouldn't clear the block. It's not ideal in my opinion, but I don't have the time or money right now to change it.
AndyF built this engine a few years back. He seems to know what he's doing, so I figure it should be OK.
[Re: lilcuda]
#2062724
04/27/16 02:59 PM
04/27/16 02:59 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yes, I made my own tool. Yes, it makes adjusting the valves easier.
