"Cat" Brand Alum water pump housings that are on ebay #2060576
04/24/16 12:50 AM
04/24/16 12:50 AM
Tennessee
727builder Offline OP
Tennessee
Have any of you racers bought and run any of the "Cat" brand Big block aluminum water pump housings? Afraid they are cheap China junk and may have issues? Any feedback appreciated.... Thanks!
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2060604
04/24/16 01:35 AM
04/24/16 01:35 AM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
Usually good quality products, I have a set of their 3d h beam rods in my 440, with arp bolts from them. When I hado everything balanced they were good only I think one or two rods needed a little grind to make them even. Hopeing to get a gear drive for my small block.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2060614
04/24/16 02:00 AM
04/24/16 02:00 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
I have one of there balancers,it was on a short block I brought,no problems
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2060655
04/24/16 06:50 AM
04/24/16 06:50 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I bought a new one at a swap meet a few years ago. I always thought Cat was a rip-off ov Scat (their rods were anyways, when they first came out), thus cheaper quality, but the price was right so i hit it. I gotta say, though i haven't mounted or run it yet, this thing looks NICE. On looks/fit alone, its a nicer product than the Mopar one and whatever other brand i've seen (cant remember now). The thing looks like it would seal without gaskets. Mine was completely unmarked and in its original box, and i had to actually read the instruction paper that came with it, in the small print to find the (Cat) brand name.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2060658
04/24/16 07:32 AM
04/24/16 07:32 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Why not rip-ovv?
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2060853
04/24/16 03:06 PM
04/24/16 03:06 PM
P
Porter67 Offline
Porter67  Offline
P
Ive used a couple of there small block gear drive back when they were like $75 and although on a street build ive not had an issue in 32k miles on one of them.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: Porter67] #2061190
04/25/16 01:38 AM
04/25/16 01:38 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
There are a few on eBay in the $50 range. Can someone provide a link? Thanks.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: cudadoug] #2061221
04/25/16 04:01 AM
04/25/16 04:01 AM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Have a small block gear drive on the shelf for 5 years never could muster the strength to run it. Someone gave it to me. Always wondered about there quality.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: BigBlockMopar] #2061231
04/25/16 05:02 AM
04/25/16 05:02 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Originally Posted By BigBlockMopar
Why not rip-ovv?
Because that makes no sense.
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: 727builder] #2061292
04/25/16 11:04 AM
04/25/16 11:04 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Just curious, what's the weight difference between the iron & aluminum housing? I've always run the factory iron one.
72 Plymouth Roadrunner 11.08@123.25
Re: "Cat" Brand Alum water pump housings that are on ebay [Re: Roughbird72] #2061996
04/26/16 01:40 PM
04/26/16 01:40 PM
dogdays Offline
dogdays  Offline
CAT was the lowest of the Chinese imports a few years ago. However more than one member here has raced with their H-beam rods.
On to the water pump housing, it's a surprise that it is as nice as has been claimed above.
R.
