68 GTX Rear Door Panel? #2061653
04/25/16 09:14 PM
04/25/16 09:14 PM
68gtx Offline OP
68gtx  Offline OP
I'm ready to install new door panels on my 68 GTX. The rear panels have no hole for the window handle. There is a square cut out where the handle goes. My question is do I take the cut out out and then just trim a round hole in that area?? Thanks Larry J
Re: 68 GTX Rear Door Panel? [Re: 68gtx] #2061723
04/25/16 11:06 PM
04/25/16 11:06 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The square is for power windows, dont take that out. Sounds like you will have to measure and it your own hole for the crank. What vendor made these panels?
Re: 68 GTX Rear Door Panel? [Re: 68gtx] #2061768
04/26/16 12:14 AM
04/26/16 12:14 AM
68gtx Offline OP
68gtx  Offline OP
Legendary from Yearone. When I got the car it came with all new interior still in boxes. Package says 68 GTX/SAT Black HTP rear black w/woodgrain. Sounds correct to me? I'm sure someone else has run into this? I will contact them and see what they say. thanks Larry J
Re: 68 GTX Rear Door Panel? [Re: 68gtx] #2061814
04/26/16 01:43 AM
04/26/16 01:43 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Seems like the hole for the crank is in a different place then the square for the PW switch. Do you have stainless trim from the old panels? It surrounds the woodgrain area.
Re: 68 GTX Rear Door Panel? [Re: 68gtx] #2061885
04/26/16 08:39 AM
04/26/16 08:39 AM
68gtx Offline OP
68gtx  Offline OP
Yes I do have the stainless for the panels which was also a pain in the a$$ to install with no holes in the panels.
Re: 68 GTX Rear Door Panel? [Re: 68gtx] #2062102
04/26/16 04:37 PM
04/26/16 04:37 PM
68gtx Offline OP
68gtx  Offline OP
The answer from Legendary is you have to cut the holes yourself. Thanks Larry J
