Hey All
Working on my bench seat again. Got my new driver side springs bent and installed. I had to replace the drivers side stop and although the original was ground with a flat as the passenger side still is, the seat backs line up perfectly now. Should I leave as is and cut and weld the bar stock I'm using for the replacement stop? Or grind it with the flat as original.
I figure I can grind both sides and get a little more tilt to the seats. Both Me and the wife are fairly tall.
