Re: SB Victor heads
[Re: CJD AUTOMOTIVE]
#2068213
05/06/16 11:54 AM
05/06/16 11:54 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Not to hijack the thread, but spoke with Don Flanagan at Crower yesterday, and the Crower stainless rocker shafts for this head will be ready in about 4 weeks....so I'm told. You will have to mill the cast stands and bolt on their steel stands and rockers. Just an option for you guys wanting to run high spring pressures or endurance applications. Hey, options are a great thing! Also spoke with TD on their progress, single shaft kit is done and has a part#...which I will post with all the other info once finished. Looks like as much as 1.8 ratio with the single shaft kit! They are now moving on to the individual kit, and then they will mock up on a 48° block to see if that's a possibility. I'm also trying to find out when the Victor head will be readily available to purchase from anywhere....
Brian Hafliger
Re: SB Victor heads
[Re: J_BODY]
#2068525
05/06/16 10:30 PM
05/06/16 10:30 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We won't be using the SV intake...it won't support big power with out a ton of porting and welding...we'll be adapting an Indy intake to our build...
We'll also be using TD rockers. If you are looking to make more than 700HP, that intake will be a bear to do it with.
Brian Hafliger
Re: SB Victor heads
[Re: Jason B]
#2068769
05/07/16 11:23 AM
05/07/16 11:23 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Are you guys bushing the lifters... or did you find a lifter that work without bushing them
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: SB Victor heads
[Re: Jason B]
#2068901
05/07/16 04:36 PM
05/07/16 04:36 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Bottom line is there are NO R3 blocks available and never will be again unless you get someone to sell you one. So either find a way to deal with Ritter and get his stuff to work or run what JUNK is left out there. The Victor head on a Ritter block has big potential and we are lucky to have someone making anything. Also guys don't forget we have to use these products and find a way to make them work or they will quit making them then WHAT??? We have nothing!!! We plan to share what we learn to help get this stuff out there and running Funny this comes up...Kent is talking to me right now about his aluminum block...we might end up trying it for our Victor build...I'm waiting on a price from him but either we'll do that or go to a 9.200 deck block.
Brian Hafliger
