Belly Pan Specs #2061004
04/24/16 08:44 PM
04/24/16 08:44 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Hi, I'm looking to build a belly pan instead of using a diaper. I can use either steel or aluminum, what thickness does it need to be, how tall of a lip needs to be around pan? Any other tips would be appreciated. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Belly Pan Specs [Re: BANDIT] #2061023
04/24/16 09:14 PM
04/24/16 09:14 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Please check the rules,,,,but I remember something to the effect of a few inches IFO crank damper to a few inches past the oil pan, valve cover to valve cover and 2 inches tall with absorbant.
I would like to do a pan also,but I use the 40 year old Super stock pan with 2 oil pick up lines.It will be need to bee a little more creative to fab up a pan.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Belly Pan Specs [Re: hemi-itis] #2061675
04/25/16 09:58 PM
04/25/16 09:58 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Thanks, I'll look a little harder on NHRA site. I have one of those super stock pans on my 64 Dodge, a Charlies, that kicks out on the bottom right up against the headers, really tight. My Avenger is a tube car and a pan should be pretty simple to do once the engine shows up. Jim.
4600 DA
