?? Painless Wiring Panel ( ign / fuel / fan / etc )
#2060698
04/24/16 10:36 AM
04/24/16 10:36 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I need some advice on this panel I am considering. I currently still have to use the standard "key" to start the car,,the cylinder is pretty sloppy and I would like to get rid of the key all together..... I have 3 toggle switches currently IN the dash for the Fuel pump, Water and Fan.... I am thinking it should be pretty easy to convert what i have over using the painless instrument panel... I enclosed a link,,,, Most of what I need to hook to the painless panel is already "plumbed" up to the dash except the ignition... Might even run the headlights to one of the extra switches on the painless unit. Does this panel look like it would do the job ?? thanks for any input,,,advice,,,comments.... Doug http://www.summitracing.com/parts/prf-50406
Re: ?? Painless Wiring Panel ( ign / fuel / fan / etc )
[Re: 69CHARGERMD]
#2061624
04/25/16 08:24 PM
04/25/16 08:24 PM
69CHARGERMD
KENTUCKY
Shorthorse,,,Thanks for the input and link,,,Going to crawl up under the dash soon and check,,,I think the previous owner has everything up to snuff with relays,,,but I will double check everything,,,,Thanks !
Mark,,,how are you !? I am working on the 65 Belvedere ( race car ) Glad to hear you like the lift,,,good choice... I bolted mine down to the floor,,,and it was a major improvement,,,no sway,,,very sturdy,,You will get a lot of use out of it,,,Not sure if you got the low profile sliding jack,,but also a nice upgrade to have.... Glad to hear your GTX is coming along,,,can't wait to see it,,,you going to Norwalk this year ? ( July i believe ? ),,,If so, i will find you and have a beer with you,,,,
Thanks everyone for the input and advice,,,,
Sincerely Doug
