Page 5 of 16 1 2 3 4 5 6 7 15 16
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2051180
04/10/16 05:53 PM
04/10/16 05:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You ain`t done yet homey LOTS of metal to remove yet........... biggrin
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2051189
04/10/16 06:04 PM
04/10/16 06:04 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Not really much left. Half a firewall and just a bit of the floor.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2051191
04/10/16 06:06 PM
04/10/16 06:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
SYCH...........
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2051381
04/10/16 10:27 PM
04/10/16 10:27 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Got the dashboard out of the car. Heavier than I thought. 44 pounds, without wiring harness.
Good time to trim the dash, and put an plastic dash cover in loose some weight. sawzall weld
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2056527
04/18/16 12:54 AM
04/18/16 12:54 AM
sgcuda Offline OP
sgcuda  Offline OP
Felt off this weekend. Today I came down with something, I don't know. So I didn't get as much done as I wanted. Fabricated rocker rails and mounting brackets. Was going to just sandwich bolt them together, but ended up welding in tubes through the 2x3's and using grade 8 bolts and fender washers to hold to the mounts. The object is to make the body lift off. All assembled, but the brackets still need to be welded to the rocker sills.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2056618
04/18/16 07:20 AM
04/18/16 07:20 AM
Mo.
racerx Offline
racerx  Offline
Mo.
This is Hot Roding at it's best sawzall weld(fabrication) thumbs......Good luck with it.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2056633
04/18/16 09:19 AM
04/18/16 09:19 AM
Parts unknown
590 Challenger Offline
Parts unknown
She's looking good
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2056780
04/18/16 02:36 PM
04/18/16 02:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good man..............hopefully soon you`ll be drive
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2060472
04/23/16 09:29 PM
04/23/16 09:29 PM
sgcuda Offline OP
sgcuda  Offline OP
Welded rocker rail brackets to rocker sills today. Bolted up rails and tack welded in c/m tubes in the rear. Holds the body from flexing around. Have to get another tank of gas before I can finish them up. Meanwhile, I made a copper ground contact out of an old length of battery cable. I think it is working much better, now. Mig welded axle housing to tubes. Was a walk in the park. Single pass. 150 amps.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2060476
04/23/16 09:33 PM
04/23/16 09:33 PM
sgcuda Offline OP
sgcuda  Offline OP
I used 1 5/8 x .083 c/m to go from the rocker rails to the main frame rails. I'm pretty sure for 25.4 cert, I need diagonal bars also, and a cross bar on the drivers side. Does anyone know the thickness spec for this? While I'm at it, does anyone have the SFI 25.4 paperwork they want to e mail me for a nominal fee?
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2060496
04/23/16 10:22 PM
04/23/16 10:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good man.............I hate you fabrican fools............. bow beer
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2064667
04/30/16 01:11 PM
04/30/16 01:11 PM
sgcuda Offline OP
sgcuda  Offline OP
Since I want to make sure this comes out right, I got my own SFI cert book. Wow! Didn't realize how many regulations there are on cage construction. Probably, the best $40 I've spent in a long time.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2064937
04/30/16 09:22 PM
04/30/16 09:22 PM
sgcuda Offline OP
sgcuda  Offline OP
After a bunch of years, the engine has finally come off the stand and has made her maiden voyage into the engine compartment for sizing.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2064939
04/30/16 09:24 PM
04/30/16 09:24 PM
sgcuda Offline OP
sgcuda  Offline OP
Needless to say, the stock front frame assembly is only there for engine height alignment. All being removed in the very near future.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2064987
04/30/16 10:36 PM
04/30/16 10:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice Kenny and you`re one step closer............
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2065063
05/01/16 01:25 AM
05/01/16 01:25 AM
sgcuda Offline OP
sgcuda  Offline OP
Was wondering if I could recoup some of my expense by selling the dashboard. Is this worth anything?
The good
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2065065
05/01/16 01:26 AM
05/01/16 01:26 AM
sgcuda Offline OP
sgcuda  Offline OP
The bad
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2065068
05/01/16 01:30 AM
05/01/16 01:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
So what is your pan for a dash? Glass?
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2065087
05/01/16 02:11 AM
05/01/16 02:11 AM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
The good
Holy crap, your car is a 6 Pack? shock
Not that it shouldn't be beat on, that's what they were made for. up However, if that's the original Vin for the car make sure you keep that tag if you sell the dash. twocents
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2065196
05/01/16 12:17 PM
05/01/16 12:17 PM
sgcuda Offline OP
sgcuda  Offline OP
WASa six pack. I bought the car summer of '79 with 32k on the clock. Drove her for about a year. Got my first trophy at National Speedway in Long Island, NY and got the bug. Went into the garage and started racing her in '82. Never looked back.
[image][/image]
