Sixpack / Holley Idle Curuit tuning question: #2060466
04/23/16 09:15 PM
04/23/16 09:15 PM
California
BigDaddy440 Offline OP
California
I've read a lot on this topic, but I'm still learning here's my question:
I have new a 440 with decent sized cam and a NEW sixpack set up. Car starts up quickly, runs at 180-185 degrees F and shuts off clean. Mechanically sounds like a beast.
CAMSHAFT: 241/247@.050" .540/.540 lift. (hyd.flat tappet)
I'm trying to get the center carb to idle "within the idle circuit" but I'm having a little trouble.
When I put a vacuum gauge on the "spark port" of center carb at idle, it's still pulling vacuum...so it seems I need to turn the idle adjustment screw out to close throttle blades more...but if I did this enough to get a zero reading on the gauge the engine would die as it cant idle at 600rpm.
I've advanced the timing to the point where I'm not sure I should go much more...about 22-24 degrees INITIAL at 850-900 rpm. I was hoping to stay about 12-15 initial.
I started the idle circuit screws (center carb,both sides) at 1.5 turns out and tried to turn them out a bit more and watched the vacuum gauge (this time on manifold vacuum) and the needle just moves around with the slight fluctuations of the idle. Basically, I'm not confident in the reading on the gauge with it moving around.
What should I be doing with the idle circuit screws? How should they effect idle? Is it too early to adjust them knowing I'm not running 100% off the idle circuit on the center carb?
I was hoping I wouldn't have to modify the throttle blades (drill holes in them etc) to get the car idle within the idle circuit, so I'm looking for answers.
Advice?
Thanks!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060473
04/23/16 09:32 PM
04/23/16 09:32 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
iirc there's an adjustment on the secondaries to open the throttle blades a bit. Then you can drop idle idle speed screw on the center carb.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Sixpack / Holley Idle Curuit tuning question: [Re: DARTH V8Я] #2060479
04/23/16 09:36 PM
04/23/16 09:36 PM
California
California
Awesome...now I just have to find them! smile
Thank you, that just may solve my issue.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060497
04/23/16 10:28 PM
04/23/16 10:28 PM
California
California
Ok, I found those little adjustment screws on the outboards. Obviously you can only adjust the front outboard idle screws and apparently have to remove the rear outboard to adjust it.
By adjust them out a little, the rpm did increase, but I didn't do it too much as I'm sure I'm leaning out the mixture when I do this.
I will remove rear outboard and adjust them out just a tad too (like the front) and see if I can get fully into the idle circuit.
I don't want to lean out the mixture too much either, as I currently have stock jetting and might be on the lean side already. (considering my cam, heads, compression etc).
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060503
04/23/16 10:40 PM
04/23/16 10:40 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You can make up for the leaning out with the center carb mixture screws. See if you can get your idle speed and ported vacuum where you want it. Why do you think you need lower vacuum than you already have on the vacuum port? What is wrong with the way it runs, now?
[image][/image]
Re: Sixpack / Holley Idle Curuit tuning question: [Re: sgcuda] #2060540
04/23/16 11:44 PM
04/23/16 11:44 PM
California
California
I've read that on the spark port, (not intake vacuum) if you are pulling vacuum on the gauge, than you're not completely in the idle circuit on the center carb. As I close the throttle blades on the center with the idle adjust screw, the vacuum on the spark port continues to decrease.
Once I have the engine idling where I want it with the spark port vacuum reading at zero, then I'll know I'm idling on the carbs idle circuit.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060543
04/23/16 11:51 PM
04/23/16 11:51 PM
You need to adjust the outer carbs. idle mixtures gently in all the way and then back the needles out 1/3 to 1/2 turn out from bottom out scope(that means removing the rear carb. to work on it or remove the front and center carbs to work on the rear idle mixture screws shruggy) Make sure to disconnect the secondary linkage and adjust that so that both sets of butterflys(front and rear carbs.) are closed at idle with the center carb butterflys closed all the way also scope Then set the center idle mixture screws out from 1 1/2 to 2.0 full turns and see if that helps thumbsMy old low deck six pak would idle that way, same thing with the replacement 1971 440 carbs I bought to compare to my original 1970 440 six pak carbs. shruggy
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060704
04/24/16 10:49 AM
04/24/16 10:49 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Out is richer, not leaner.
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BSB67] #2060710
04/24/16 10:57 AM
04/24/16 10:57 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And,until the ends are right center adjustment will do little or nothing.
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060744
04/24/16 12:13 PM
04/24/16 12:13 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
All you guys are misunderstanding his question.
His problem is, the engine is not getting enough air to run on the idle circuits alone. He is opening the center throttle blade to far to get idle rpms higher but then he is on the transfer circuit. You can not adjust the outboard throttle blades to allow more air at idle like you can on the secondary throttle blades of a DP. This is a common problem with six pack setups
Re: Sixpack / Holley Idle Curuit tuning question: [Re: sixpackgut] #2060749
04/24/16 12:26 PM
04/24/16 12:26 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That's a common problem with all carbs. once you get 1.5 turns out on a mixture screw that's at the approximate limit that that circuit will carry, rpm is down, so you crank on the throttle setting and get you extra fuel. Once you give the engine the required fuel for good idle he won't need the extra throttle opening for rpm. In my experience with the six packs 5/8 out on the outboards and that will typically give you enough adjustability on the center, again up to 1.5-1.75 turns out. If the engine is still climbing in rpm, you may need to go more than 5/8 on the outboards. my twocents up
Re: Sixpack / Holley Idle Curuit tuning question: [Re: BigDaddy440] #2060895
04/24/16 05:15 PM
04/24/16 05:15 PM
CA
crackedback Offline
crackedback  Offline
CA
No fricken way does that engine run close to right with 12-15* initial. Get rid of that notion. My 340 with a 241 at .050 cam has 24* initial. Starts up in 100+ degree weather with a flick of the key.
It's going to want in the 20's, where you are. Let the engine tell you, not some notion or desired number that you feel is correct.
Re: Sixpack / Holley Idle Curuit tuning question: [Re: crackedback] #2061180
04/25/16 01:24 AM
04/25/16 01:24 AM
California
California
Thank you for that, that may be the case. It fires up instantly right now and sounds great, so my timing might be very close to being where it needs to be.
Thanks for the great info here guys! I feel like I have the info now to dial these suckers in! smile
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
