Source for Ring & pinion for early '50's Dodge pickup #2060276
04/23/16 12:51 PM
04/23/16 12:51 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Does anyone have an idea where a more street friendly gear for a '51 Dodge pickup can be had.I have a friend looking at a truck to purchase,it is a 3/4 or 1 ton Dodge with what appears to be a floating single rear wheel axle.Current gear ratio limits top speed to about 45mph! Thanks for any leads,RT
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: RTSrunner] #2060326
04/23/16 02:43 PM
04/23/16 02:43 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
I would suggest checking with Roberts or Valley
http://www.vapinc.com/
http://www.robertsmotorparts.com/store/
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: RTSrunner] #2060423
04/23/16 07:14 PM
04/23/16 07:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've been in that situation before ('58 Ford F350 with 5.14's), best to change the whole rear end.
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: John_Kunkel] #2060531
04/23/16 11:32 PM
04/23/16 11:32 PM
IN
ahy Offline
ahy  Offline
IN
I'm guessing it has 5.8x or 5.9x which is not the best for cruise. Vintage Power Wagons has or used to have NOS 4.xx gears for these rigs. That would increase cruise speed... if the (I guess) 230" flattie has the torque to handle them. I still run the OE 5.8x gears on a '47 1 ton PW. Practical cruise speed is 43-45 MPH. I do run it heavy from time to time. Theoretical rated top speed is 55 MPH but I don't think the engine would like to run there very long.
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: John_Kunkel] #2060552
04/24/16 12:10 AM
04/24/16 12:10 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
iagree
Had the same problem my self in truck in pic.. Had Dutchman supply me with a bolt in 9" ford... LOTS of stuff for that rear end....
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: RTSrunner] #2061141
04/25/16 12:13 AM
04/25/16 12:13 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
According to my 54 Factory service manual, A full floating hypoid 4.1 was available in a "D" model designation (1 ton) with an optional 4.89 and a power wagon could have had a 5.83 or a 4.89. Everything else listed is lower then 5.89 gears.
That would indicate to me, factory highway friendly gears are probably not available, unless 3500 rpm at 60mph is highway friendly.
If you want highway friendly gears, swap in a highway friendly modern rear axle assembly. There are a lot of choices that can be fit to your truck pretty easily. Gene
Re: Source for Ring & pinion for early '50's Dodge pickup [Re: RTSrunner] #2061177
04/25/16 01:20 AM
04/25/16 01:20 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks for all the input guys,I'll forward it to my friend.I was thinking an axle swap also,but I think he likes the wheels! I will post if he gets the truck and what the decision is on the axle choice. ~RT
