Re: 69 b body hemi leafsprings correct finish?
[Re: ScottSmith_Harms]
#2059829
04/22/16 05:36 PM
04/22/16 05:36 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Dipped as an assembly clamps and all, paint was extremely thin, not glopped on thick stuff. Hangers were raw steel. good info! thanks!
[Re: domingo]
#2061696
04/25/16 10:24 PM
04/25/16 10:24 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
I just pulled the rear springs off and apart on my grand pops 69 Roadrunner he gave me. I found black paint runs in between the leaf springs so I'm guessing they were dipped as an assembly and where the springs were compressed together with that weird looking bolt, the paint didn't get cause it was so tight.
inherited a 69 roadrunner from my grand pop.
[Re: domingo]
#2062077
04/26/16 04:05 PM
04/26/16 04:05 PM
Posts: 103 muskegon MI
v cummins
muskegon MI
good deal!!! so i will assemble them and "dip" ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) them in black paint afterwards!!! You must have a big tank. What paint are you going to use with how much reducer.
[Re: domingo]
#2062090
04/26/16 04:19 PM
04/26/16 04:19 PM
fuelishnsilly
Greenwood Lake, NY
My plans are to assemble them and somehow hang them like they were mounted on the car and just lay some heavy coats of paint onto it. I'd imagine I would get runs like that too.
[Re: fuelishnsilly]
#2062115
04/26/16 05:02 PM
04/26/16 05:02 PM
v cummins
muskegon MI
My plans are to assemble them and somehow hang them like they were mounted on the car and just lay some heavy coats of paint onto it. I'd imagine I would get runs like that too. Whether you dip or spray them you will want coat them individually with DP-90 first so they don't leach rust. And if you go with the dipping process you will want the DP-90 coverage for the thin paint to cover with out being to thick.
[Re: v cummins]
#2062278
04/26/16 09:32 PM
04/26/16 09:32 PM
domingo
EL Master
EL Master
Lima, Peru
good deal!!! so i will assemble them and "dip" ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) them in black paint afterwards!!! You must have a big tank. What paint are you going to use with how much reducer. LOL!! thats why i typed dip betwen qoteation marks. No way Im gonna dip them. No I dont have a tank that deep and most of all, I dont have enough money to waste on filling a tank with paint just for dipping a couple leafsprings!!! LOL I will just shoot em gloss black with a paint gun and go a bit thick and then hang em. Good enuff for me! I already dissassembled, blasted them, epoxy primed em for rust protection, and Im assembling them again with brand new zinc interliners, plastic spacers, clamps and insulators. they will also be getting new front spring eye bushings...and then ill spray em black as I said.
[Re: domingo]
#2063115
04/28/16 12:17 AM
04/28/16 12:17 AM
Posts: 238 Florida, US
72ls5fla
Florida, US
I just purchased the front bushing from Frank B. fit perfectly.
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
