Re: Mopar done making wedge blocks
[Re: 71Pan]
#2060234
04/23/16 11:25 AM
04/23/16 11:25 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
The Edelbrock small block and big block heads fit factory blocks, which are cheap and plentiful right? That has got to be were their big sales numbers come from. Only the hard core guys are buying NEW wedge blocks.
As far as their new Hemi Power Package, I don't have any idea where the blocks will come from. Original blocks are scarce. If you buy a new Indy block, why not get Indy heads? So who will supply blocks for all the E-Brock Hemi heads?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: 71Pan]
#2060238
04/23/16 11:30 AM
04/23/16 11:30 AM
Posts: 1,237 North Central, Indiana
Roughbird72
This just still boils down to Return On Investment for anyone/company producing blocks. Sad, but true.
72 Plymouth Roadrunner 11.08@123.25
[Re: 71Pan]
#2060337
04/23/16 03:29 PM
04/23/16 03:29 PM
Roughbird72
Edelbrock or any other reputable company would probably do it, IF they knew they could sell enough(thousands)to justify the expense.
[Re: 72Swinger]
#2060506
04/23/16 10:49 PM
04/23/16 10:49 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
the thing with the pontiac stuff is, one size fits all. 326-455 share the same block structure. with the mopar stuff, you have guys that want a small block, and guys that want a big block. then it's iron vs aluminum. which one do you build, in order to turn a profit?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: 71Pan]
#2060532
04/23/16 11:34 PM
04/23/16 11:34 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Pontiac is also a "Legend" company now since they no longer exist. So when Fiat milks "Chrysler" for all its worth and it also becomes "Legend", then maybe we will get some good blocks? Look at all the flack Ritter caught on here, yeah that makes people really want to cater to this crowd.
Mopar to the bone!!!
[Re: Pale_Roader]
#2060676
04/24/16 09:51 AM
04/24/16 09:51 AM
Posts: 12,416 Taxes & Virus's R-US, NY
Dragula
Do most ov us REALLY need an aftermarket small block? Whats the upper HP limit on a 340 block?
Really, your questioning why we need them? I guess ignorance is bliss. And 600hp is about the limit of the stock block if you want it to stay alive more than a season or two. Which is so easily attainable with Indy heads or W8 heads, its almost a grenade on borrowed time if you build one with a stock block, let alone use any kind of power adder. What really sucks here is the after market has been so slow to pick up the Mopar stuff and bring it to the next level...From what I have been seeing, its never going to happen. I have talked to some vendors, and it always seems to be the same answers, the Mopar people don't spend the money, at least not in the respects that the loyalists from other brands do.
[Re: 72Swinger]
#2060680
04/24/16 10:06 AM
04/24/16 10:06 AM
Posts: 3,396 Pa
Hot 340
Pa
Look at all the flack Ritter caught on here, yeah that makes people really want to cater to this crowd. I can tell you didnt plop down 3k plus for no-talent machining paperweight.
[Re: Pale_Roader]
#2060740
04/24/16 12:00 PM
04/24/16 12:00 PM
Roughbird72
When the HP potential of current cylinder heads is higher than stock block limitations, i believe that speaks for itself. Most resto & your average street/strip car probably doesn't need an aftermarket block, but these days 600-650 HP is fairly easy to achieve & stock blocks were never engineered to run safe/reliable at or beyond that level.
[Re: 72Swinger]
#2060742
04/24/16 12:05 PM
04/24/16 12:05 PM
Posts: 9,873 MI, usa
dvw
MI, usa
There is more demand for a Pontiac block? I haven't seen a handful of Pontiac powered cars at the track in years. I would bet the BB Mopar has a larger following than even the 429/460 Ford as well. The trouble is as bad as people say the stock blocks are they still power a lot of race/street hot rods. There were a lot of them built, plenty left out there cheap. Try and find a good stock 455 Pontiac block. Once the supply of stock blocks drys up things might change. Doug
