Magnum manifolds or Summit Headers
#2059421
04/22/16 12:43 AM
04/22/16 12:43 AM
Posts: 201 Martin TN
ridin98ci
Martin TN
I have a 73 Duster with a 318-auto....exhaust manifold is cracked so I need to replace it....I have already have a set of magnum manifolds from a dakota, would they fit??? I like the idea of free or I have thought of the cheapo summit headers...I am VERY low or no budget or the wife will force the sell....lets hear some advice yall
LOUD AND PROUD!!!
Re: Magnum manifolds or Summit Headers
[Re: ragin sonny]
#2059440
04/22/16 01:10 AM
04/22/16 01:10 AM
ridin98ci
Martin TN
I wonder if they will fit with PS and my kickdown BS???
LOUD AND PROUD!!!
[Re: ridin98ci]
#2059498
04/22/16 03:05 AM
04/22/16 03:05 AM
RapidRobert
I have already have a set of magnum manifolds from a dakota, would they fit??? I like the idea of free. I am VERY low or no budget or the wife will force the sell. No brainer there! Are these the early 92/93 ones with the ~2&5/16 outlets or the later ones with 1&7/8 outlets? big difference in performance and their value. I dont think with headers you would like the cost/addit'l parts needed/fitment headaches
[Re: dogdays]
#2060000
04/22/16 10:29 PM
04/22/16 10:29 PM
Posts: 3,344 Central TX
roe
Central TX
The placebo effect. IIRC the 340 manifolds and the Mag manifolds were within a few hp of each other when tested back-to-back.
R. I remember that article. All of them, including the low po stuff, we're right about the same. Not worth the money IMO to buy one vessels the other when headers are so much better bang for the same buck
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#2060012
04/22/16 10:45 PM
04/22/16 10:45 PM
RapidRobert
The problem I see is that the early (92/early 93) mag manis are ~2&5/16 outlets and are very nice pieces whereas the later ones are 1&7/8 which is the dia of one header pri tube on my last BB. yes they would fit (that is important!) and would be fine for a DD 318. the very best manifold combo is a 68-70 340 HP pass iron manifold and an early mag dr side manifold (what I have on the stock car).
[Re: dogdays]
#2060016
04/22/16 10:53 PM
04/22/16 10:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
R. IIRC the engine used was fairly mild and the exhaust may not really matter at that level.
[Re: ridin98ci]
#2060196
04/23/16 09:51 AM
04/23/16 09:51 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Don't waste your time with the manifolds.
My 5.9 Duster went from 14.2 to 13.0 with a swap from manifolds to headers.
"I think its got a hemi"
[Re: ridin98ci]
#2060198
04/23/16 09:51 AM
04/23/16 09:51 AM
gdonovan
Oakdale CT
I wonder if they will fit with PS and my kickdown BS??? Will not fit on the drivers side with power steering.
[Re: RapidRobert]
#2060221
04/23/16 11:06 AM
04/23/16 11:06 AM
DaytonaTurbo
Manitoba, Canada
The problem I see is that the early (92/early 93) mag manis are ~2&5/16 outlets and are very nice pieces whereas the later ones are 1&7/8 which is the dia of one header pri tube on my last BB. yes they would fit (that is important!) and would be fine for a DD 318. the very best manifold combo is a 68-70 340 HP pass iron manifold and an early mag dr side manifold (what I have on the stock car). I've heard this several times about the outlets being much smaller on the later year magnums. Any idea why they did this? And can the later ones be opened up to the large size or is the casting totally different?
[Re: ridin98ci]
#2060380
04/23/16 05:02 PM
04/23/16 05:02 PM
ridin98ci
Martin TN
Mine are the early big outlet manifolds.....some say they fit others say they don't.....looks like I am gonna have to try them....to the fella that said just go with headers....I'd love to but like I said my wife is watching the budget super sharp as we have one son getting close to college and she is planning our 20th anniversary trip to the UK so little to no cash spent is my goal
LOUD AND PROUD!!!
[Re: ridin98ci]
#2060660
04/24/16 08:15 AM
04/24/16 08:15 AM
gdonovan
Oakdale CT
Mine are the early big outlet manifolds.....some say they fit others say they don't.....looks like I am gonna have to try them.... The magnum drivers manifold will NOT fit with power steering in an a-body, period. Feel free to give it a go.
[Re: gdonovan]
#2060761
04/24/16 12:42 PM
04/24/16 12:42 PM
RapidRobert
Mine are the early big outlet manifolds.....some say they fit others say they don't.....looks like I am gonna have to try them.... The magnum drivers manifold will NOT fit with power steering in an a-body, period. Alright solved, looks like I'm gonna have to take em off your hands
