Page 3 of 4 1 2 3 4
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2058783
04/21/16 01:49 AM
04/21/16 01:49 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
found this one but I want a small block. Can a 318 or 360 be installed on a 6 cylinder K member?
http://boise.craigslist.org/pts/5544695020.html
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2058786
04/21/16 01:52 AM
04/21/16 01:52 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
so these newer ones cant be used? This is a 318 thats blown. 2000 yr
http://boise.craigslist.org/cto/5535321961.html
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2058809
04/21/16 02:41 AM
04/21/16 02:41 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If your not intending on using the efi, and will go with a carb, any Dakota truck would probably work. I'd have to take a look under that 4 door truck and see what the frame looks like, and if the drop will be in a good position for whatever cab/body you intend on putting on it.
As far as the V6 to V8 motor, the mounting pads on a Dakota bolt to the frame and those brackets are engine specific. 3.9 fits a 3.9, a 318 fits a 318, and the 4.7 fits a 4.7. How they might interchange between motors is anyone's guess. These days, all the electronics are motor specific, so swapping from, say, a 4.7 to a 318 means you get to swap the complete wiring harness and computer and you better have everything that matches the motor and trans (that came out of a Dakota, or the wiring will be wrong) you want to use. Weather the motor mounts are the same or not becomes a minor issue, you would probably use the ones attached to the motor you pulled out of a Dakota, and they will probably bolt to the frame.
The next thought on the motor mount is will the engine will remain in its original location as a hot rod is built? With my coupe, I moved the drive train back 7". Once you move the motor, whatever was there originally is a pretty mute point. In my case, I just added a 1/4" plate and moved the motor brackets and trans crossmember back the required distance (used what fit the motor and trans and adapted it to the frame where I wanted them to sit).
If you have the ability to swap a frame from one vehicle to something entirely different, motor mounts should be just another step in the frame swap process. Use whatever mounting brackets fit on the motor of choice, and modify them to fit the frame. Gene
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: poorboy] #2058901
04/21/16 11:32 AM
04/21/16 11:32 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
This is my project truck
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2059682
04/22/16 01:54 PM
04/22/16 01:54 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Just recently saw a similar vintage Stude that had the 'treatment' and it was very sharp.
As Gene mentioned, you might start with a comparison of wheelbase dimensions and pay attention to where the rear axle kick-up is positioned.
If you are an accomplished fabricator/welder then making a frame fit your truck should not be all that scary. These frames don't mind being reworked.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: wayfarer] #2059800
04/22/16 04:32 PM
04/22/16 04:32 PM
dogdays Offline
dogdays  Offline
I believe the round Dakotas are quite a bit wider than the square ones.
R.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2060118
04/23/16 02:12 AM
04/23/16 02:12 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
the v6 and the v8 use the same motor mounts---we have put a 5.2 in the spot the 3.9 fit----also the motor mount ears actually unbolt off the frame---i have saved several sets and have just recently handed a couple to a friend so he could use them mounting a 5.7 hemi in his 34 plymouth coupe----the gen 1 dakota is just fine for the job at hand--i would watch for a single cab short or long bed.....
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: savoy64] #2060549
04/23/16 11:57 PM
04/23/16 11:57 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Yep, V6 / V8 use same mounts. I just did two swaps using 87 Dak chassis. One for a 52 Dodge pu and the other for a 56 Dodge pu.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2060559
04/24/16 12:32 AM
04/24/16 12:32 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
also if you find a 96 truck with 6 bolt hubs you can just switch hub rotors to get the 5 on 4.5 pattern----with the 97 up dakota you are stuck with the 6 bolt rotors----there is a bigger choice in the 5 on 4.5 world....
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RodStRace] #2061318
04/25/16 12:16 PM
04/25/16 12:16 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Originally Posted By RodStRace
Dave, sorry to hear the rod went away. Hope you got decent money out of it.
As said, the early ones had the 5 lug pattern. Only 4s and V6s except the Shelby until 92 with the bowed nose.
96 and newer have OBDII, so you will want to avoid them or change it to an earlier drivetrain unless you want to mess with computers and wiring!
I'd look for a 92 318 magnum, 518 without torque converter.
You can install the whole wiring/PCM or swap to a carb-intake and electronic dist.
The trans will take any 727 converter.
You will have to swap discs in front for the 5 lug, and redrill or swap axles in back.
Here's one you could probably have together fairly quick aside from the rear fenders
http://cgi.ebay.com/ebaymotors/1948-DODG...=item2c53ee0840
There are guys here and the other site that have done these year trucks....
This one popped up recently
http://boise.craigslist.org/cto/5553288642.html
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2061655
04/25/16 09:17 PM
04/25/16 09:17 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
RUMBLON
OK, so we drive down to Boise and bought this truck. 1992 Dakota 318 magnum. Started right up and sounds GREAT! Drove it onto my trailer for $200.00.
Im going to use it on some project, just not sure what, either this Studebaker truck or keep looking for another mopar projecT.
Im wondering what all I can use from this rig, it has power windows, AC, and it has an OD button, so it has over drive I am guessing.
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2061774
04/26/16 12:24 AM
04/26/16 12:24 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Pictures don't work, but you can use nearly all of that Dakota. I used everything from a 90 Dakota on my coupe except the roof and cab back panel, Door shells, inner door panels, glass, the box sides, and about 200 lbs of odd stuff. Then I cut up the sheet metal and used most of it for patch panels. What you can use is only limited to what you can imagine a use for something. Gene
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: poorboy] #2061785
04/26/16 12:51 AM
04/26/16 12:51 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
The pics are not showing up for you? Anyone else, they are showing up for me.
Am I correct that the wheelbase for this truck is
130.9 in (3,325 mm) (ext. cab)
According to what I can find on line my studebaker truck has a 112" wheelbase. So I will start planning and collecting parts if I go with this truck. I have a lot to get done on this shop before I can start building in it.
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2061890
04/26/16 09:08 AM
04/26/16 09:08 AM
moparx Online content
moparx  Online Content
super steal at $200 !! would be a super deal if the engine or transmission were blown . good score and a ton of parts to use !
beer
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2062342
04/26/16 11:03 PM
04/26/16 11:03 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Pictures worked today, guess my computer just didn't want to show them yesterday. That looks like a great deal for $200, I would have bought it without a second thought. Gene
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RodStRace] #2062400
04/27/16 12:25 AM
04/27/16 12:25 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I was an rv mechanic years ago and I drove the company's 90 ish Dakota and once the owners pride a 76 corvette. The 318 Dakota was way faster and handled pretty good to.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2062446
04/27/16 01:25 AM
04/27/16 01:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Daks around here are like gold apparently. Some scrapped out beaters with no titles are asking $1000. No thanks. Been looking for a pre OBDII V6 manual trans one for my project, but no luck so far.
Don't be the exception.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #2062512
04/27/16 03:29 AM
04/27/16 03:29 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
That looks freaking amazing for $200. Definitely a good score! I'd save it for an older coupe project, but that's just me.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: Supercuda] #2063358
04/28/16 01:41 PM
04/28/16 01:41 PM
W
wayfarer Offline
wayfarer  Offline
W
...don't know exactly where you are located, and yes, I do know that West-Texas is a huge area.....but it didn't take long to find these. Hook up that trailer and get moving. up
http://abilene.craigslist.org/cto/5522104391.html
http://sanangelo.craigslist.org/cto/5545440312.html
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: wayfarer] #2063865
04/29/16 10:23 AM
04/29/16 10:23 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Thanks, first one is gone, second one is automatic. BTW, second one location is home. But I am literally all over W. Texas, so it don't matter.
Page 3 of 4 1 2 3 4
